I have to take a form of transpotation and modify it. I wantto do it to a scooter(gas, electric). I don't knowwhattodo though.
stick chrome wheels on, neons underneath and methanol in the tank, double the bore on the exhaust. EDIT: spinners, chrome spinners.
methanol in the fuel tank, start with petrol, and gradualyl increase the mix, so you dont blow it up. Increase the size of the air intake and filter, strip the weight down. design a better performance exhaust.
Nitreous boost setup? (Just kidding by the way. Do not mess with that unless you really know what you're doing)
yeah, methanol as a fuel can be dangerous/disasterous too. 100% methanol as your fuel will break it, and probably injure you.
Remove the wheels and make it hover with a hoverskirt and things like that. Less resistance so you'll be faster and it's amphibious. Efficient!
replace the engine with 2 1000HP petroleum turbines and give it wings, and maybe considering a seat belt or ejector seat would be wise.
