Modding I Need Ideas
Discussion in 'Modding' started by cerberus76, 18 Nov 2003.
  1. cerberus76
    cerberus76 What's a Dremel?
    18 Nov 2003
    I'm new to the forums but I have been doing some modding for the last six months or so. I'm contemplating several projects, including one that was inspired by the Vesper HTPC, which just plain rocks.
    As a network technician, I have access to a wide variety of older cases that are just crying out to be placed back into service and modded for current use. The most notable one, and the largest, is an old Compaq Prosignia 740 Series Server case. It's free so I don't much care what happens to it, I just need some ideas on mods or themes to get me off on the right foot.
    Thanks in advance to everybody for contributing.
  2. Solarius
    Solarius What's a Dremel?
    3 Oct 2003
    Give us some pics, its hard to think up ideas without visual aides.
    ( Dremel of the "signia" on prosignia :dremel: ) :)
  3. cerberus76
    18 Nov 2003
    Will Do
    I'll get some pics up and running as soon as I get them downloaded off the camera this evening.
  4. Bossman
    Bossman What's a Dremel?
    6 Nov 2003
    What about doing something really radical like cutting the side panel and putting perspex in there instead, so its like a window into your case!
    Seriously, i think the best mods these days are original ones, that no-one has atempted or only thought about doing.
  5. WizardLock
    WizardLock What's a Dremel?
    15 Nov 2003
    I find looking at galleries online for some ideas always help. Here is a list of some good links:
    • http://www.caseumbau.de/index.php?page=gallery/gallery/
    • http://www.coolcasegallery.net/ccg/
    • http://www.gruntville.com/gallery_front.php
    • http://pcdb.overclockers.com.au/
    • http://www.casemodgod.com/
    • http://www.moddin.net/gallery.asp *****
    • http://twistedforums.com/forums/index.php?c=4 ***
    • http://www.hardforum.com/forumdisplay.php?forumid=13
  6. cerberus76
    18 Nov 2003
  7. shroom
    shroom What's a Dremel?
    6 Aug 2003
    I have an entire room of scrap pcs I picked up off the road (bulk trash pickup = modding junkies best friend) that are in the same situation as that prosignia. I have an old IBM tower thats 2.5ft tall, and the tape drive is still in it :)
  8. FearsomeMouse
    FearsomeMouse What's a Dremel?
    22 Oct 2003
    Experimentation is the best way...
    Heya,
    If you have so much access to cases and alike then you could pick up a few and hav a bit of a muck around with them - since rendering them completely and utterly useless is of no concern, you could really get your mind onto things / try things out and see if you like them on some other cases before moving onto your final project - the server case. Once you get started (if your anything like me) then you wont be able to stop :dremel:
    Then the ideas will really just flow... The advantage to this is that you'll be able to create something that is really you, and not an imitation of something that someone else has done that your not sincerly happy with. :rolleyes:
    Having said that, do draw on others ideas as well as this should help you / spark your mind on new and better things. As Bossman said, it doesn't have to be completely original - as long as its what you want it to be. Plan and experimentation in my short - lived experiance is the best key to making something that your truely happy with as well as developing your case modding skills.
    That is all from the study driven case modder... :wallbash:
    --FearsomeMouse
  9. cerberus76
    18 Nov 2003
    Brainstorm or Brainfart? You make the call
    OK, so I was sitting around the other night and in a flash it came to me... Why not mod the side panels to work like gull-wing doors?!?! I could purchase a very small hydraulic pump that could even swing them open with a remote control. I know it sounds hugely ambitous, but I've got nothing but time, and all sorts of cases to experiment with.
    Let me know what you think, or if somebody has already tried putting this together.
  10. FearsomeMouse
    22 Oct 2003
    Sorry about the late reply
    Sorry about the late reply!
    I think your on to something. It will probably cost a bit to do... but like most good things - they cost money!
    I bid you good luck on your case modding endevours. Let us know how it turns out!
    --FearsomeMouse
