I need your help
Discussion in 'bit-tech Folding Team' started by MLyons, 26 Jan 2018.
  1. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Right then. Since the launch of the new forums I'm sure you guys have noticed that the Folding BB code now doesn't work. If any of you can provide me a link of what it should look like and what website it is polling it would be great. I see that folding is still part of the forum and i personally really like the cause so want to fix it. Any info on it will help.Thanks.
  2. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    Hi there - it would be great to get this fixed.
    The Folding sigs came from ExtremeOverclockers - mine looks like this (the number is the persons unique ID):
    https://folding.extremeoverclocking.com/sigs/sigimage.php?u=146070&bg=0
    ... and this is how the code worked in the old Folding Forum (here the numbers are the persons Folding name and the team code):
    [folding]un=DocJonz&t=35947[/folding]
  3. MLyons
    3 Mar 2017
    I've seen some using "n" or "u" instead of "un" is this just an error on their part?
  4. DocJonz
    24 Apr 2009
    I think 'u' expects the persons Folding name and 'n' expects the Folding team name.
  5. MLyons
    3 Mar 2017
    so you can use t or n?
  6. DocJonz
    24 Apr 2009
  7. MLyons
    3 Mar 2017
    So I've looked into this and if possible in the new forum software it seems it will take way more dev time (a solid week) than it's worth unfortunately. To best solution I can offer is to use the image version. Sorry all :sad:
  8. DocJonz
    24 Apr 2009
    That's a shame :sigh:
  9. MLyons
    3 Mar 2017
    So after 6 hours and lots of alcohol this now works again!!!!!!!!! :)
    javaman likes this.
  10. DocJonz
    24 Apr 2009
    Hurray :clap:
    Great job - sounds like a few pints well spent :hehe:
    MLyons likes this.
  11. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    It still work or broken?
  12. DocJonz
    24 Apr 2009
    The visual EOC sigs don't work on the current version of the Forum.
