I want a New TFT
Discussion in 'Hardware' started by Cyberbob:-), 15 Feb 2005.
  1. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    Right guys my 19" CRT is finally on it's way out and I want it replace it with a 19" TFT of 2 17" TFT's.
    Can anybody reccomend a good 19" for about £350 with good response time for games. This seemed promising Viewsonic VX912 but PC Pro
    Quote"It's a shame it doesn't go any further though, as our technical tests revealed issues with colour balance. Full spectrum ramps looked weak in the red area of the spectrum. There was faint banding on colour graduations too, and also a steep run-off at the extreme ends of the colour range. Photos still look good, but it does mean colours can't be entirely trusted for accuracy"
    But it can be had for MD
    I mean you can get a really good 17" for less than £200, so do I buy two really good 17" IIYAMA Monitor ProLite E435S-B ?????
    Could I run two together with games no problem...or would it cause problems??
  2. Guest-16
    Guest-16 Guest
    only 1 monitor will be used for games. Both 19" and 17" usually have the same native res too - 1280x1024.
  3. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    17" for gaming tbh.
    I got two 172x's. Best gaming/looking monitor imo.
    - S
  4. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    TFT's have seen a huge price drop in the past 2 months or so, you can get a good 17" one for £150, LG and Samsung is often considered the best, and style is nice too.
    You should note that the max resoulation for TFT is 1280x1024, and with 19" it tends to look a bit weird. Response time should be <16ms, but preferably <12ms.
  5. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    Most games only allow one monitor for games, although some do support two. Imo get something like a sharp 172G-B (is that right?!) or any other quality make and you'll be fine.
    <A88>
  6. TMM
    TMM Modder
    12 Jan 2004
    depends what you mean. If you mean run both so its like one big screen for the game, then probably not (depending on graphics card and the game itself, but 99% of the time, no.).
    If you mean play a game on one and have the desktop on the other at the same time, then usually that will work no probs.. for me anyway, although this will cause you to get frame stutter if there is something graphical happening on the non-game monitor.)
    2x 17" all the way imo!
  7. Cyberbob:-)
    16 Jun 2002
    Looks like I might go for the 17" IIYAMA Monitor ProLite E435S-B only £184 from PCnextday. It's only 10ms too. Or the sharp 172G-B £257 for the DVI one. Is the Iiyama one any good? or can anybody reccomend anymore?
    I still might get two, not sure now. :wallbash: I shall get one for now and maybe buy another one later :D
  8. Hiren
    Hiren mind control Moderator
    15 May 2002
    Go for the Ilyama they are fantastic screens (mate has a similar model).
  9. Henchman:crg
    Henchman:crg What's a Dremel?
    9 Feb 2005
    Just returned a Iiyama CRT
    The quality of the new Iiyama CRT monitors is hopeless.
    Just read a magazine review that says Iiyama are now using cheaper poorer quality parts, and the monitor I returned was certainly in that catagory.
    Shame, they used to make great quality stuff.
  10. Cyberbob:-)
    16 Jun 2002
    Has anybody got a Iiyama ProLite E435S? Who can comment on them?
    I mean at nearly £70 cheaper than the sharp. I'll be £70 closer to getting a second one...
    Think my head is spinning now :hehe:
  11. Mace
    Mace Ohh, it stings.
    9 Dec 2003
  12. Cyberbob:-)
    16 Jun 2002
    Looks nice mate, But it looks like only silver available over here. I would like a black one. Also it says 15ms not sure why? Maybe different because uk to usa version..
    The silver one is £230 over here, not bad thou.. :D
    Oh! and thanks for posting some links to some pics for me...
  13. Guest-16
    Guest-16 Guest
    It's actually the API and the game specifically as all gfx cards now can spread things across an extended desktop.
