Overclocking i5 2500k how to test
Discussion in 'Hardware' started by Groovedude, 15 Jan 2013.
  1. Groovedude
    Groovedude Minimodder
    29 Aug 2003
  2. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    The longer you run it without errors, the more stable your overclock will be (up to a point). Once I've achieved what I think is a stable overclock, I will tend to keep Prime95 running pretty much all afternoon/evening to test it. So you're probably looking in the region of 6-8 hours of testing.
  3. Groovedude
    29 Aug 2003
    Thank you :)..... I shall leave it be then.
  4. Shirty
    18 Apr 1982
    Or do what I do. Overclock it to where you want it and use it as normal. If it doesn't crash, it's stable enough for me ;)
  5. Groovedude
    29 Aug 2003
    Not a silly answer, many people give this response when I searched on google. :)
  6. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    I usually take this approach as well, but I have to admit it's a bit annoying to have intermittent bluescreens months later while trying to work or play games. Bumping Vcore up a notch solves that issue though.
  7. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Pretty much what I do.
    I will bump the multiplier up to start with 48 and set the Vcore to 1.35v and then see if it boot's in to windows, and if it does I load up Realtemp and Prime 95 and run it.
    If it crashes then I bump the voltage up and try again and repeat, but I never go above 1.410v on the Vcore.
  8. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    1.4 is probably my max for 24x7, but I have had 1.52V through mine for brief testing at 5.3Ghz on air, and 1.6V will get mine to boot at 6Ghz under sub ambient water.
    Very good overclocking chips the early ones of these, some of the later ones can be a bit poo when you want to push it. But 4.5Ghz is definitely possible, and 4.8Ghz is highly likely.
  9. Elton
    23 Jan 2009
    I find that Overclocking these babies I tend to crank it up as far as possible without touching the voltage. Then I push the volts. Then I turn down the volts.
    Then I realize, sod it, 4.4Ghz @ 1.2-ish is fantastic and just settle on that.
  10. mrbungle
    20 Sep 2004
    Clock as far as you can on stock volts.
    Just work up from the 40 multi and run 20 passes of intel burn test
    Repeat till u get a fail and then work from there if you want more add some volts.
    Easy as.
  11. damien c
    31 Aug 2010
    I put about 1.525v through mine for 5.2ghz under water and temps remain perfectly fine, but the voltage is to high so I only use that for benchmarking.
  12. rollo
    rollo Modder
    16 May 2008
    keep things sub 1.4 vcore for 24/7.
    i usauly just prime it for 6-8hrs and be done with it.
    Have also done what others have done but its very anoying
  13. Elton
    23 Jan 2009
    Once you hit about 4.5Ghz diminishing returns on the rest of the processor.
    Then again I like low volts.
  14. Groovedude
    29 Aug 2003
    i got to 4.2Ghz.. using the above bit-tech guide.. it seemed to BSOD anything higher. i will work further at weekend i would like a little more 4.3/.4
  15. Taniniver
    Taniniver Minimodder
    24 Aug 2010
    There is always some variation of course. I found I can take mine to 4.4 Ghz with no additional voltage, but it becomes unstable at 4.5, so I run it at 4.4.
  16. Elton
    23 Jan 2009
    Aim for a 1.3v stable OC.
    I can hit 4.4 with 1.28v.
  17. Groovedude
    29 Aug 2003
    i used the volts from this thread:
    i think it may have been a turbo setting i had enabled making it BSOD, so im gunna try again upping.
