Build Advice i7 930 or i7 860? Help!
Discussion in 'Hardware' started by Yukster, 16 Apr 2010.
  1. Yukster
    Yukster What's a Dremel?
    15 Apr 2010
    The i7 930 (130w) clearly got the vote over the i7 920. I did some further research and i came across the i7 860 (95w) which is apparently newer and cooler! the 930 and the 860 re both similarly priced. So which one shall I get?
  2. xMathiasD
    xMathiasD What's a Dremel?
    15 Mar 2009
    i would get the 930 ^^ - so if you are going to make a sli setup or crossfire its x16 + x16 on the pci ekspress lanes, instead of x8 + x8 (i7 860) and then you have the tri channel ram on 930 ^^
  3. Xonar
    Xonar What's a Dremel?
    2 Nov 2009
    To be fair, this only results in around a 1-2% difference in performance which is almost negligible, if you were going tri-SLI or crossfire then my answer would differ but if you had that kind of budget I'm sure your mind would be made up already.
    If you do a lot of heavy encoding to utilise the triple channel memory then go 930 but you could save yourself around £100 by opting for the 860 without almost any drop in peformance and spend the money else where (GPU etc).
    But if money isnt a concern and you have the budget for it, 930 + X58.
  4. Cosmot
    Cosmot What's a Dremel?
    12 Apr 2010
    first, 930 860 have the same frequency
    second, 860 stronger than 930 in the automatic overclocking
    third, 860 and 930 is not a platform
    users select for 930 certain to overclocking, However, from the ordinary overclocking, they can be said that there was no difference in fact. I believe most people are not willing to ignore cpu warranty. and 860 cheap, recommend to buy 860!
  5. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    CPU warranties are pretty irrelevant as CPU failure rates are extremely low. This is a tech enthusiasts forums and "most" people are interested in CPU based overclocking.
  6. rollo
    rollo Modder
    16 May 2008
    My old 920 is still running at 4ghz stable has been for 2 years now just about
    930 is better at achieving high overclocks
    860 I'd call it a cheap end peace of crap even though there same price
    if you use any high memory usage program 930 destroys 860.
    Main dif in price is x58 board
    You get what you pay for
  7. Xonar
    2 Nov 2009
    Hardly :eyebrow:, care to back that up with some evidence?
    Destroys seems a little strong, I wouldnt have said more than 5-10%, even if that.
    Not to mention the extra for triple channel memory.
  8. wyx087
    15 Aug 2007
    the question here is not about choosing the CPU, the CPU is nearly identical. only difference is that 860 runs cooler and has better turbo mode.
    the question here is are you prepared to spend £80 more on a platform (CPU + motherboard + RAM) for no noticeable performance difference?
    860 and 930 uses two different platforms, so to do a comparison, you will need to consider the platform cost. and 860 centred platform costs about £80 less.
  9. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
    Nonsense!
    More nonsense...(as already stated, there is not much difference between them)...
    ________
    Sick From Avandia
  10. cybergenics
    cybergenics What's a Dremel?
    27 Jun 2009
    Not necessarily. Had two 920's replaced one with a 930, which matched the slower 920 but couldn't go as far as the quicker one, 3.9 vs 4.2.
    Built a system for a friend with a 930, also wouldnt go past 4.1. So in 4 CPU's, two 920's and two 930's, the highest clocking sample was a 920. Tested on two P6T variants and an X58 EVGA.
    First 920 d0 got 3.9 ish
    second 920 got 4.25 ish (both prime stable)
    first 930 got 3.9 and was flaky
    second 930 got 4.1 rock solid
    Not really an invite to throw an extra 35 quid at the 930 is it ?
    So unless you are overclocking and get lucky, why waste the extra cash on a 930, like I did.
  11. Cosmot
    12 Apr 2010
    It is clear, the 930 and the 860 re both similarly priced and similarly performance! if you like newer and cooler!, you select 860.:wallbash:
  12. Ph4ZeD
    22 Jul 2009
    I'm sorry, wheres the evidence that the 860 runs cooler than the 930? Also, the 930 is newer than the 860.
  13. cybergenics
    27 Jun 2009
    If you need more memory ultimately, a 1366 system running 12GB of ram will be cheaper than going from 8gb to 16gb on an 870. In fact as 4gb sticks of DDR3 are insane money, it is way cheaper.
  14. wyx087
    15 Aug 2007
    have you even read my post? i said platform cost, not the cost of CPU.
    that is true, both platform will be really, really expensive. and think about the price to pay when upgrading 12GB to 24GB.......
    and fixed the typo for you :)
    about running cooler, at stock, it should run cooler if both were using identical aftermarket cooling. this is given the fact Intel used a much smaller heatsink for 860, confident that it runs cooler than 920/930.
  15. adam_bagpuss
    24 Apr 2009
    y not just save the money and get the i5 750 which is much cheaper almost £100. only thing you lose is HT so unless your intop heavily threaded apps then just get the i5-750.
    unless your not overclocking then i would say get the i7-860
  16. Cosmot
    12 Apr 2010
  17. Yukster
    15 Apr 2010
    Which platform?
  18. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    As far as I'm aware, H55 and H57 chipsets were introduced to take advantage of built-in GPUs in Intel's Clarkdale CPUs (ie. certain core i3 and i5 processors.)
    Since you're probably not in interested in integrated graphics, nor does your processor of choice even include it, you can stick with P55 boards.
  19. Yukster
    15 Apr 2010
    That makes sense. Although if I went for a H57 Mobo, I could upgrade to a Clarkendale CPU later on without needed to change the Mobo.
    So what H57 MoBo do you recommend?
  20. adam_bagpuss
    24 Apr 2009
    P55 is a better chipset though,
    you would be downgrading if you swapped your 860 for a i3 or i5 to support those silly intergrated GPU features
