CPU i7 970 Hex-core rumoured.
Discussion in 'Hardware' started by Fazed, 3 Feb 2010.
  1. Fazed
    Fazed Minimodder
    5 Jul 2009
  2. Pete J
    Pete J Employed scum
    28 Sep 2009
    Huh, apparently it 'only' runs at 3.2GHz :jawdrop:
    This probably being the 'budget' intel hexacore, I wonder how much it'll cost? £500? If it's reasonable I may be tempted (because so many games out there will benefit from those two extra cores :eyebrow: ).
  3. Fazed
    Fazed Minimodder
    5 Jul 2009
    Minesweeper and Solitaire will never have looked so good :D
  4. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    Well as the i7 965 & 975 both cost over $1100 I would say we are looking at $1200 minimum for this new 970 Hexa-core CPU.
    I read the sorce but if the 975 is a Quad-core CPU then wouldn't a Hexa-core be a higher number like the i7 980x. I think the i7 970 will be a 3.2GHz non extream Quad-core in line with the *970, *980x, *995 (*= Not out yeat), or something like that. Like with the Fist Gen i7 family of 920, 940, 965EX or Second Gen i7 Family of 930, 950, 975.
  5. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    nope, itll be less as it isnt an XE (unlike the 975 or 980)
  6. azrael-
    azrael- I'm special...
    18 May 2008
    I've read something about the 6-core "Gulftown" not running quite as fast as expected. Something about software only taking advantage of 4 of the cores?
    Personally, I'm more looking forward to the i7 930, which should incorporate all the updates previously only found in the LGA1156 versions. I might be wrong, though.
  7. shah
    shah Minimodder
    29 Jan 2010
    Yes you are right azrael. Looking forward to the i7 930 myself but if they release a hexa core 970 at a good price I might get that.
  8. Fazed
    Fazed Minimodder
    5 Jul 2009
    Standard intel pricing for flagship models (XE) chips are around $1100.
    So, if the 980XE is going to be $1100, I would expect the rumoured 970 to be around the $850 mark.
    You'll find the quad-core 975XE drops from it's current pricing point as it's no longer the flagship model.
  9. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Intel had such a good plan going for naming... then they throw in the Dual Core i5-6xx some priced over the quad i5-750 and the hex core 970 when the 975 is quad... why...
  10. dec
    dec [blank space]
    10 Jan 2009
    i thought the hex cores would be i9 1xxx and not i7 9xx. are the hex cores gonna be 45 or 32nm?
  11. barndoor101
    25 Oct 2009
    32nm
    all the new cpus (hex core 970, quad core 930) are gonna be 32nm Westmere CPUs.
  12. jason27131
    jason27131 Lolzers
    6 Feb 2010
    I'm sticking with my i7 lol. Useless hexacore, since most things can't even take advantage of 4 cores.
  13. she'shighvoltage!
    she'shighvoltage! What's a Dremel?
    24 Sep 2009
    I thought the 930 was just a 920 rehash, not a die-shrink?
  14. cdb
    cdb No comment
    25 Apr 2009
  15. droitwichdosser
    droitwichdosser What's a Dremel?
    25 Apr 2009
    Now this is why i bought i9...
    I now have an upgrade path that doesn't involve buying a whole new motherboard :rock:
  16. barndoor101
    25 Oct 2009
    My bad, looks like the hex core 970 is the only new i7 chip on westmere. the 930 looks like a higher clocked 920 (on 45nm still), which is a missed opportunity by intel.
    no such thing as i9. you mean i7/socket 1366.
