The latest firmware for the IB-MP309HW-B will make the following changes to the device:- Browser / System ================ - Improvement on font engine character rendering (30% speed up) - faster navigation on local drives, use numeric key to input item number to jump to the page where item is located - Improved fileplayer speed - Fixed HDMI display output blackout issue for auto EDID - Updated network share and webservices language packs. - Removed EXT2 option for NMT installation Note: due to long term reliability issue with EXT2 on device that is frequently turned off abruptly - Additional symbols can be input from "1" key - HTTP download manager (only works with links with special "download" attributes). - File player hide Recycle Bin folder - Fixed 'TV MODE' + '3' key handling bug - Fixed recovery kernel no red screen displayed - Browser image caching fix, should fix some YAMJ crashes or no image issue. - Fixed HDD spin-up during standby - Fixed slow loading of HTML pages Web Services ============ - New UI - customizable icon feature with browse image utility (need NMT apps) - bug fixes on customizable service icon with browse feature. - Web Services page modification - Fixed a "save/remove service" bug - Now able to customise JPG/BMP icon - Fixed slow IR response while playback Internet Radio - Immediate response to STOP during Internet video streaming - Fine-tune Web Service UI Network ======= - Improved SMB server startup time - Improved browsing time for SMB client - Atheros USB WiFi stability fixes - Fixed SMB client hostname resolution picked up wrong IP address from the IP list - Fixed file copy failed from HDD to SMB/NFS with names containing whitespace - Fixed UPnP AV server playall issue broken in previous release - Fixed Samba server halts after device name change - Torrent client is now by default Transmission (btpd removed) **** IMPORTANT NOTE: Please ensure completion with previous downloads with BTPD as new Transmission client cannot inherit previous downloads **** - Fixed torrent schedule page not working - Fixed occasionally newly created SMB/NFS shares doesn't show up in media source list - Atheros USB WiFi added support for TP-Link v2 stick - Fixed persistent private IP when DHCP server unavailable (e.g. cross-cable connection etc) Playback ======== - Bookmark/resume for single playback - 10 bookmarks available now - Press stop to bookmark the last video playback - Press enter / play with focus on bookmarked clip to resume - Press "0" to start from beginning of clip - Auto framerate synchronisation - Framerate sync function in ISO playback, only for 50,60Hz modes (PAL/NTSC) - switch to NTSC(60Hz) when selected mode not applicable (previously, it will follow TV mode selected) - Use 59.94 for NTSC when matching content detected. - Fixed incorrect data shown on infobar. - Fixed after ISO playback, screen goes blank when framerate sync kicks in - Improved info display - Disable incorrect video MPEG1/2 VBR display. - Fixed incorrect framerate info for video playback (*.mov, *.mp4). - Fixed video bitrate calculation error (less 1 packet every second) - Modified infobar UI (height, spacing and text displayed) - Fixed info bar losing text after paused - Improved accuracy of mpeg1/2 bitrate information - Photo app - Fixed JPEG (PNG / TIFF transcode) from myiHome server cannot be displayed - Fade-In Fade-out effect added for photo transition - Enable large jpeg rotation. (downscale before rotate) - Fixed faded color for jpeg at 360-deg rotation - TV Type setting for DVD playback - the TV type setting is now working for DVD video playback (4:3 and 16:9 only, 16:10 will treat as 16:9) - DVD Menu - new popup menu if MENU key on PCH remote controller is pressed - user can select to jump to ROOT, TITLE, CHAPTER.... etc from the menu - Modified progressive zoom and pan in ISO/IFO playback - Removed up/down keys as prev/next track - VCD *.DAT playback fixed using soft demux - Fixed "repeat" keypress in myiHome when playback audio caused picture playback to halt - Improved handling of MKV H.264 profile and vlevel. - Fixed cannot stream MPEG from UPnP AV server, liveTV - Fixed *.pls file unable to start when playback locally (HDD/SMB/NFS) - *.m3u playlist supported. - Fixed TS with stream6 as teletext playback cause out of memory - Fixed MKV H264 L4.1 pixelated video issue Subtitle ======== - Fixed subtitle parsing with BOM (UTF8 support only) - Changed default subtitle font size to 28 and Y offset to 10 - Exception handling in SSA subtitle parsing - Slight adjustment of subtitle position NMT === - Improved on samba client browsing time and server boot up time - Fixed occasional slow samba response - Upgraded to nzbget 0.51 - Upgraded to nzbgetweb 1.2 (Categories can be modifed in /mnt/syb8634/nzbgetweb/setting.php5) - Fixed FTP password saving - Improved Setup Page loading time - Fixed HDD spin-up during standby , Hungarian, Dutch, czech, Bulgarian language added. download from here:- Firmware 01-17-090125-15-DST-403-000 Stand 07.04.09
