News IBM and TDK partner up to make MRAM
Discussion in 'Article Discussion' started by Tim S, 23 Aug 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. mmorgue
    mmorgue What's a Dremel?
    16 Feb 2005
    Sounds very promising, once the storage capacities increase to more real-world requirements.
    Almightyrastus On the jazz.
    21 Mar 2002
    will be interesting to see how the power usage turns out as well esp if there are possible plans to replace hard drives at some point in the future. Of course power usage will also affect heat and as a result access speeds.
  4. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    I want to see how they plan to sheild against severe EMI and outside sources of magnetism.
    if they can successfully do both then it might replace ECC memory in number crunching stations for CAD and the like, where the improved speed would lead to faster analysis times.
  5. pendragon
    pendragon I pickle they
    14 May 2004
    I agree. This issue immediately lept to mind when I heard it was magnetic.
  6. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    Interesting stuff! Good to see more alternatives to the old hard disk :)
    PS: noticed a typo in the last paragraph.
  7. Glider
    Glider /dev/null
    2 Aug 2005
    Current HDs are magnetic too, and they seem to do fine?
    Faradays Cage to the rescue ;)
  8. completemadness
    completemadness What's a Dremel?
    11 May 2007
    I'm guessing that huge antiferromagnet (or whatever) has something to do with it not getting destroyed by EMR
  9. Bluephoenix
    3 Dec 2006
    a Harddrive is not that sensitive to magnetism when on or off because you have to drag a magnet across the disc (or across the side to it for perpendicular recording) to realign the cells and create read errors. with the MRAM, any severe EMI could cause a bit change (and subsequent read error) based upon the design shown.
  10. completemadness
    11 May 2007
    Correct
    I'm pretty sure that's wrong - you just have to move the particles through the magnetic field to destroy them, where you put the magnet (or the alignment of the cells) doesn't really matter
  11. Bluephoenix
    3 Dec 2006
    personally tried it with a half-dead disc, and it is indeed correct.
  12. completemadness
    11 May 2007
    whos right ? lol ;)
  13. Bluephoenix
    3 Dec 2006
    I meant that I tried running a magnet at 90 degrees to the disc, on a half dead perpendicular recording drive, and more sectors turned up with errors.
    so that would be me who's right.
    but you did have a point, which is why I resorted to physical testing in the first place! :D
Tags: Add Tags
