IBM hard disk failure?
Discussion in 'General' started by Dremel_Freak, 25 Aug 2001.
  1. Dremel_Freak
    Dremel_Freak What's a Dremel?
    18 Mar 2001
    One of my 15Gig IBM deskstar's has just failed and I've been hearing stories of even the new 60GXP's failing quite alot too - anyone know why? Is it due to the high FSB's that people are running these days or is IBM's drive reliability going downhill?
    Any thoughts?
  2. Bursar
    Bursar What's a Dremel?
    6 May 2001
    I would suspect (but I don't know for sure) that the drives reliability is the sam as the previous models.
    I think they have just become so popular now that when they fail you hear about it from lots of people.
    I'm sure Maxtor/Seagate etc drive fail on a regular basis, but they don't seem as popular so you don't hear about it as much.
    Just my tuppence worth :)
  3. Koolvin
    Koolvin The Modfather
    12 Mar 2001
    I have had problems with these drives.... The problem is the connections on the PCB if you unplug/plug your HDD alot then it weakens these connections causing failure.
    Don't buy IBM if you are like me and like to swap hardware in your machine 3 times a day!
  4. RTT
    RTT #parp
    12 Mar 2001
    one of my maxtors went tits up about a week ago :rolleyes:
    when i RMA it it'll be the 2nd hard drive i've had to RMA in a month :(
  5. herbs
    herbs Nobody but us chickens
    7 May 2001
    Yep my one sort of died, due to the connection. If u moved the connector then it would work again it was a bastatd if it moved on its own when burning. So many wasted cds :(
    4-6 week wait for replacement :(
