Case Mod - Complete ⭐ Ice Age Project
Discussion in 'Project Logs' started by Tech Cave, 8 Nov 2019.
  1. Tech Cave
    Tech Cave What's a Dremel?
    18 Sep 2019
    Hi guys! i'm back with another project!
    This time the theme will be, as the name says, snow and ice, so white will be the main colour!
    Hope you guys like it and leave a comment down below if you have any questions!
    Sa mod pc design likes this.
  2. Tech Cave
    18 Sep 2019
    Let's start with the core of every project, the cpu! Thanks to my sponsor PC HUNTER!
    This time i'm on AMD side with this little beast! Ryzen 5 3600 :D
    [​IMG] [​IMG] [​IMG] [​IMG]
  3. Tech Cave
    18 Sep 2019
    Let's continue with the motherboard! a X570 PRIME PRO thanks to my awesome sponsor ASUS Republic of Gamers!
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  4. Tech Cave
    18 Sep 2019
    And now, there's no winter inside a pc, without a proper cooling, and this time my sponsor ALPHACOOL has provided anything i need to let the winter come! Thanks!
  5. Tech Cave
    18 Sep 2019
    It's time to unveil my case of choise for this project!
    Thanks to NOUA that has provided this awesome IRON V9 with a set of 6 of their beautiful SKIRON fans!
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  6. Sa mod pc design
    Sa mod pc design Minimodder
    7 May 2019
    Which chassis will you use?
  7. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Neat looking fans. I'm curious to see the fan's performance curves. I'll have to do some googling after work.
  8. Tech Cave
    18 Sep 2019
    It's the Noua Iron V9! :)
  9. Tech Cave
    18 Sep 2019
    Thanks man, for sure when the mod are finish i'll do some testing on it and make a review on my channel!
  10. warboy
    warboy Insane modder
    24 Nov 2011
    Good start!
    What camera do you use? :clap:
    Tech Cave likes this.
  11. Sa mod pc design
    7 May 2019
    Ventole bellissime Simone ottima scelta
  12. pcroombrasil
    pcroombrasil Minimodder
    27 Nov 2017
    nice case
  13. Tech Cave
    18 Sep 2019
    Thanks! It's the Sony a5100!
    warboy likes this.
  14. Tech Cave
    18 Sep 2019
    Thanks bro!
  15. Tech Cave
    18 Sep 2019
    Grazie Ste!
  16. Tech Cave
    18 Sep 2019
    Thanks, as i said in the previous posts is the Noua Iron V9 :)
  17. Tech Cave
    18 Sep 2019
    Here we are again! While waiting for the last parts to arrive, i've started to modify the case.
    Today i've create a replacement for the front mesh using epoxy resin with light blue UV reacting pigment, to simulate an ice slab and i'm satisfied with how it came out.
    At first my doubt was to make a polished one or a matte one, but at the end i choose the matte one because i think it look better, here the pics of the process!
    As you can see, it took a lot of sanding process in order to get the right thickness, and due to the fact that the resin heat up and get softer during the process it has take a lot of time to do it.
    Dot_Kappa and Cheapskate like this.
  18. Tech Cave
    18 Sep 2019
    Here's the psu for the mod, thanks to our friend at Riotoro with their Enigma 850W G2!
    TodMod likes this.
  19. Tech Cave
    18 Sep 2019
    Hello Guys! Here the last pieces for the mod! Thanks to my friends in OCPC USA for the support with this awesome 32gb ram kit and the RX580 8gb!
  20. warboy
    24 Nov 2011
    crazy idea bro! I'm curious
