Hi guys, thanks for reading... I want to add 6 hard drives to my serveur, looking for something not too expensive, I found a 6 hdd cage from Icydock, who else? Anyway, this product is availiable in different online shops, with a large range of prices from 70euros to 148euros ... but for all of them, in the description, the product dimention is the same on all sites: Product Dimension (L x W x H) : 146.5 x 145.8 x 41.3mm but sorry but...the product description is :ExpressCage MB326SP-B= 6 Bay 2.5” SATA HDD / SSD Hot Swap Cage for External 5.25” Bay. 6 bays for six HDD inside a box of 146.5 x 145.8 x 41.3mm ???????? Unless I've lost my mind, 146.5mm means 14.65cm no?, so in a square box of let's say... 15cm/15cm and 4 cm height, you're supposed to cram 6 HDDs???? I don't buy it I've got dozens of HDD here, and even taking out the slimest ones, some Seagate are only 2 cm height, but most are 2.5 cm height, but in all cases, 3 HDDs piled up are over 4 cm, without mentioning that 2 hard drives stuck together side by side make already 20.5 cm width, but looking at the pictures it's obvious that there are 6 drawers, I am totally confused Please, does anybody knows the real dimentions of this product? I found until now, 7 sites with the same odd dimentions
Had one of these in the past, and a Startech version They are 146.5mm deep, 145.8mm wide, and 41.3mm high They support 7mm to 12.5mm HDD/SSD's max
Those are the real dimensions: it's for 2.5" (laptop) hard drives and SSDs, not 3.5" (desktop) hard drives.
