IcyBox IB-MP301-B
Discussion in 'ICY BOX' started by steveo_mcg, 7 Mar 2009.
  1. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    My mums box won't play sound on certain files, is there an updated firmware for this box?
    I can't find what type of files they are just now but i'll update this when i get to my own computer.
  2. Nathan@Nanopoint
    Nathan@Nanopoint Ctrl Alt Del
    2 Feb 2009
    Hi
    The IB-MP301-B was the first model put into production, the later models support many more formats including MKV. Please check your file formats and give details on which formats you are experiencing difficulties with.
  3. Louise
    Louise What's a Dremel?
    10 Mar 2009
    Hi
    Last year I brought an IcyBox IB-MP302-B IDE Media player with a 3.5 hard drive and it worked perfectly, this casing unfortunately broke and we got a new one and used our old hard drive. However now it seems to have a error where you watch about an hours worth of film then it cuts out and it says there is nothing in the memory. When its plugged into the computer all files are still there however it wasn’t registering when plugged into the TV. Have you heard of this before and is there anything I can try to resolve this problem.
    Many thanks
    Louise :)
  4. Nathan@Nanopoint
    2 Feb 2009
    Hi Louise
    I've not heard of a problem like this before and due the nature of the fault it would be best to return it to us so that our technical department can test the unit with different hard drives. Do you know when the unit was purchased? all Icy Box come with a 12 months warranty. If you wish to return the unit for our technical department to look at you will need to fill in a RMA request form for a returns number. Click here for service
    I hope that the unit is still in warranty. If the unit turns out to be faulty, the unit will be repaired and you will be back to watching your movies in no time :)
  5. Louise
    10 Mar 2009
    Hi Nathan,
    Many thanks for you response. I only purchase it last week so i will call the company i brought it from and if they wont help i will come back to you for help as it is definatly in warranty.
    Thanks again
    Louise
  6. steveo_mcg
    26 May 2005
    Just checked the files which don't play the sound are XVID where as the files that work correctly are DIVX5 however both use mp3 for the sound layer. Any ideas does this box support Xvid?
  7. Nathan@Nanopoint
    2 Feb 2009
    Hi Stevo_mcg
    The IB-MP301 does not support Xvid...
    If you require Xvid support I would suggest looking at the IB-MP308
    Video formats:- WMV: WMV9, ASF: WMV9, MP4: MPEG4 Video,
    DAT: MPEG1, VOB: MPEG2,
    MPG/MPEG: MPEG1/MPEG2,
    TP/TS/TRP HD-MPEG2/SD-MPEG2,
    ISO, IFO, AVI: MS-MPEG4v3/XviD/WMV9
    Or the IB-MP3010HW
    Video formats:- MPEG-1, MPEG-2, MPEG-4: AVI, MPG, VOB, IFO,
    DAT, MPEG2 TS, XviD
