Networks Idea for my Car.
Discussion in 'Hardware' started by Mighty Yoshimi, 14 Sep 2008.
  1. Mighty Yoshimi
    Mighty Yoshimi Motormouth
    4 Sep 2006
    I had the idea earlier today of putting a Small form factor pc into my car and having it run off the engine. and somehow hooking it up to my satnav http://www.pioneer.co.uk/uk/products/25/111/241/AVIC-X3-II/index.html. Using wireless from the car could i set it up so it synconised my media files from my home pc when i wanted it to when i was in range, I.e parked on my drive?
  2. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    If all you are going to be using it for is music, you could consider a Microsoft Zune which has a wireless sync function. You can get car adaptors for them and it would be a lot simpler than a car PC and also use less power.
  3. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    It wouldn't be as awesome though!
    In all seriousness, I've heard great things about the Zune.
  4. Mighty Yoshimi
    4 Sep 2006
    that's true can the zune play video through my sat nav?
  5. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    if your sat nav has TV inputs then yes.
  6. Cupboard
    30 Jan 2007
    The only problem with the Zune is that it isn't quite as awesome as having a PC in your car :)
    just had a look at your sat-nav - it looks awesome!
  7. wolfticket
    19 Apr 2008
  8. Mighty Yoshimi
    4 Sep 2006
    Sweet Cheers, how much of a drain is a pc in a car on performance? it's 307bhp so hopefully it won't make much difference
  9. Matticus
    Matticus ...
    23 Feb 2008
    Shouldn't affect performance at all as it will get 12voltz0rs from the battery. I know a few people with car PCs, they run at extra battery as it can be quite a drain on a single battery, especially an OEM cheapo one.
  10. Mighty Yoshimi
    4 Sep 2006
    ahh right how is the second battery charged?
  11. Matticus
    Matticus ...
    23 Feb 2008
    Same way as the first I think, some sort of splitter. I don't know the ins and outs of it though.
    But in parallel obviously, if you did them in a series you would have 24 volts.
  12. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    a single decent battery will be fine as long as you don't want to run the computer for long periods with the car off.
    while running the alternator will have more than enough juice.
    google the M2-ATX power supply, its designed for car applications (car turn-over, voltage rise/drop)
  13. Ending Credits
    4 Jan 2008
    1bhp = 745.7W apparently
  14. Cupboard
    30 Jan 2007
    But not all of that will be used by the alternator, otherwise the car wouldn't move.
  15. mrbungle
    20 Sep 2004
    You only really need a extra battery when you have huge audio installs
    A computer pc will have minimal drain.
  16. Cupboard
    30 Jan 2007
    Headlamps ~50W, car PC ~50W I think.
  17. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    You only really need an extra battery if you want to run a PC with the engine off. With the engine one, the alternator should be able to supply sufficient current to run a small-ish PC. The accessory 12V lines in my car are rated at something like 120W without the need for an extra battery.
    The M1/M2/M3-ATX is built to handle all of the various over- and under-voltage conditions found in a car, and turns itself off when the battery power gets too low.
  18. Mighty Yoshimi
    4 Sep 2006
    ahhh right so performance decrease will be minimal! thanks :D
