I have this butt ugly power button: Note that the hole for the bottom is cut to go inwards, kind of recessed. Obviously, this button is indeed ugly, and plain, and horrid. The only thing i can come up with is to paint it blue and hope it just blends in with the case. Anyone have any other ideas???? Thanx -cLoWn
That means drilling the holes wider, or making my own small button, the guide ot make your own is pretty good, maybe i could try that out. hydrogen18 your old avatar piccie was much better than the ev0l m0nster fan, and it also matched "phear the hand". Just my opinion. -cLoWn
Hey. Check this out... Might look cool in a clear case, so you can see the mounting bracket and stuff. On mine, the whole mounting bracket on the back of the bezel glows.
That is the guide i was refering to in my 2nd post, tis urs isnt it Bard? @ Bard. -cLoWn PS I fried my Dremel(copy), so cant do it yet if i wana do that
my .02 - remove buttton, drill out large chunk of middle, replace with small piece of acrylic (/plastic, etc.), paint button, find some way to place LED in back of button, replace button. now you have a painted glowey button
