Electronics Ideas on switching multiple circuits from a single momentary switch?
Discussion in 'Modding' started by tacticus, 26 Dec 2006.
  1. tacticus
    tacticus What's a Dremel?
    14 Jan 2006
    I am currently designing some pcbs to hold quite a few LEDs for monitoring the activity of drives in a RAID array(RAS i know) in total there are 32 leds that link to the card in 8 groups
    4 groups of error LEDs and 4 groups of activity LEDs
    Each group is comprised of a common + and seperate - for each LED
    up to this stage i have everything under control and think it will be fairly easy heres the problem
    I want to be able to switch off/on the leds using a momentary switch
    as in when i push the momentary switch i want it to close the circuits and when i push the momentary again i want it to open the circuits
    At first i was considering using several relays (1 per group on the + connection into the group.) But i do not know if this would work
    any ideas?
    The device that will be providing the connections for the leds
    http://www.newegg.com/Product/Product.asp?Item=N82E16816115031
    it provides +3.3 volts on 1 of the pins in each group of 5 in the horizontal pin groups at the top of the card
    the momentary part of this is kinda required because i havn't found a toggled version of the bulgin illuminated switch :(
  2. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    Sounds like a job for a flip-flop (nice write up by cpemma; although it applies to fans, you can substitute your led supply there...).
  3. tacticus
    14 Jan 2006
    hrrm hoping that i am reading this (electrical nub for now)
    that looks like an awesome idea. i think i shall go get the components for that today when the shops open and after i have a sleep (night shifts make for odd sleeping patterns)
    /me continues to peruse cpennas site
    hrrm i suppose i better take some pics of this project and chuck them up when i am done :)
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    If you were wanting to cycle through several (up to 10) sub-circuits, moving on to the next module every time you press the button, a 4017 decade counter plus debounced switch could be used.
