Modding Ideas? Traffic light
Discussion in 'Modding' started by GreatSilverWyrm, 28 Feb 2005.
  1. GreatSilverWyrm
    GreatSilverWyrm What's a Dremel?
    28 Feb 2005
    I got this from my brother, where he got it...I dunno..
    It was a traffic light, it runs of 4 D cell batteries. Underneath the amber cover there, there's 2 really bright amber LEDs, hooked up to a little circuit board. I tried to find a manual for it on the internet to find out exactly how it worked, but all I could find out is that somehow you can set it to flash, or steady-on. At the moment it flashes. As near as I can tell it's got a light-sensetive switch, there's 2 holes on one side and one on the other, if you cover them it comes on.
    I'd like to mod it or incorporate it into a mod or something. I really have no ideas, so.. any ideas you have would be appreciated.
  2. purepope
    purepope Banned
    17 Jan 2005
    yeah me and my friend got 4 of em lol, they ran on a big battery, they where cool but theres a 120$ doller fine for each of them if u find em, coz they are the councils :DDDDDDDDD
  3. Mr.DMCA
    Mr.DMCA What's a Dremel?
    27 Feb 2005
    I guess you could always shove one in your case.....lol :hip:
  4. nick01
    nick01 What's a Dremel?
    6 Nov 2004
    Can you see any chips or is it all potted in epoxy? A datasheet for one of the chips may show you the "typical" application. Otherwise browse for applications of the CMOS version of NE555/NE556. I think you will find something.
  5. Mr.DMCA
    27 Feb 2005
    you could set one in the window.....put those clamps on your fan leds that make em pulse. If the big one is light sensitive then the pulse of the leds should trigger the biggy. Of course, that may blind you if your case is on your desk. Gnarly thought tho.
    :hip:
  6. smoguzbenjamin
    smoguzbenjamin "That guy"
    6 Sep 2004
    It's good for people peeking off your screen at a LAN though :lol: just blast em with a flash of that :D
  7. GreatSilverWyrm
    28 Feb 2005
    It'd be kind of cool to find one of those sensors they use in the sound-reactive ccs. I thnk you know where I'm going with that.. :)
  8. T-MINUS 10
    T-MINUS 10 Banned
    13 Feb 2005
    ooooooo, i like the idea :D :hehe:
  9. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    You could paint a case with yellow and black diagonal stripes and write on it with big letters under construction or get an image on the web and print it and work with it. your light on top would look cool
  10. KidModder
    KidModder What's a Dremel?
    22 Dec 2004
    Me I would strip it down. make a differant switch (or add one) and put it in my case fo a external powered light :D :D
  11. mjwizards15
    mjwizards15 What's a Dremel?
    2 Mar 2005
    Hey
    Hey Josh u could use the LED light to put where the time used to be or somewhere in your disk drive.
  12. KidModder
    22 Dec 2004
    wrong thread jd
  13. mjwizards15
    2 Mar 2005
    u should probly try to put the Led lights in your mouse :idea:
  14. Blue Raven
    Blue Raven What's a Dremel?
    25 Sep 2003
    It might be cool if you could rip all the electronics except the leds out and use it as a massive ide activity light. Then you could mount it on top of your computer or monitor. Might be kinda distracting though.
    Do you have any pictures of the insides?
