I got a virus in my mail.... I have just formatted my pc twice....and flash my bios. because of this and now..... I cant clear my IE setting.....anyone know how to fix this problem?
Bet ya anything it's just an older version of IE As the older (like 5.x) IE installs did not have an option to delete cookies directly, so you just have to hit "Delete Files..." then check the box that says "Delete All Offline Content" or whatever and hit OK in the popup dialog that comes up. And just check your cookies folder (it's located in your windows root folder) see if theres any in there, if so, then just get a washer program like Clean Disk 2002. Hope that helps
yup i think wat you said is right... its ie 5.00.3700.1000 was afraid it was a virus or something... hehe i cant update it cuz if i do my eMule will get low ID. Any....solution so that eMule gets a high ID if i upgrade IE6 ++ ??? Currently using Win2K service pack 4
Never used eMule so I have no clue what your talking about Try the latest version of IE 5.x though, it'll be a lot more stable than what your using And yeah, kinda figured you we're using 2k, as 5.0 is installed default onto it, and even 98se you can throw 6.x onto But I'm just rambling, so I'll shudd up now.
As for Emule Go HERE And get the latest lsd mod and extract all the files to your emule directory (C:/program files/Emule) and click yes when prompted for the overwrite This mod gives you a high id and speedy dl's everytime, its one of the best
