News IE trails browser benchmarks
Discussion in 'Article Discussion' started by CardJoe, 30 Jan 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. naokaji
    naokaji whatever
    8 Dec 2006
    I think it was wrong to include opera 10 as it's a alpha version, they should have included 9.6 or so instead.
  3. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    the graph shows firefox scoring around 1.5 sec, and the text says 2.5
    which to believe?
  4. azrael-
    azrael- I'm special...
    18 May 2008
    It's not so strange, that the regular WebKit engine fares slightly worse than one used in Chrome, since rendering engine as such isn't tested. What is tested is the JScript performance, and Chrome uses its own V8 engine for that. AFAIK, the regular WebKit uses something else.
  5. Laitainion
    Laitainion What's a Dremel?
    16 Jan 2006
    But then it wouldn't have been a test of next generation browsers anymore. Since they're all pre-release, any of them could improve. All this really proves is that Opera and Microsoft have more work to do than the rest.
  6. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Both - 1.5 sec is well under 2.5 sec!
  7. Goty
    Goty Minimodder
    13 Dec 2005
    They probably didn't include Safari because the windows version couldn't complete the test without crashing...
    =P
  8. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Well, I gave IE8 a try and I think it's far better than IE7 still I'm running FF 3.1 Beta 2 right now.
    And if they wanted to make it a next gen comparison why not include FF 3.2? Opera is alpha so I don't see why not include the 3.2a1pre of FF.
    Might actually give it a try later.
  9. C0nKer
    C0nKer What's a Dremel?
    25 Dec 2005
    IMO Chrome is much faster than its competitors. Although a bit buggy.
  10. Gremlin
    Gremlin What's a Dremel?
    31 Aug 2008
    i personally think they should either test all betas all alphas or all release candidates otherwise its not really a fair showing imo
    they should also show benchmarks for the current stable versions of said browsers (IE7, Opera 9.xx FF 3.0.xxetc etc)
  11. Nicb
    Nicb Let's discuss among ourselves
    12 Nov 2008
    Firefox RULES!!!! and thats it,......done......no more talking about it. Joking :p
  12. UncertainGod
    UncertainGod Minimodder
    18 Oct 2007
    I think the reason they tested the versions they did is because these are the first versions to include the javascript acceleration technologies.
  13. robyholmes
    robyholmes I'm under your desk...
    17 Jan 2008
    Isn't FF3.1 in beta 2? And doesn't Beta 2 have the new Java engine on default and beta 1 doesn't? I think they need to improve on which versions they are using.
  14. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    <3 Chrome, and it's fastest - Just so simple, it seems like opening an explorer window to surf the web, Firefox, Ie and Opera all seem far too cluttered when/if you go back to them :l
  15. eXpander
    eXpander What's a Dremel?
    17 Nov 2008
    I`m also a FF fan, been using it for 1year, but I uninstalled version 3 after 4 days. Got really pissed when I was dld-ing a 1.4GB file and while browsing, FF crashed and my dld stopped (I already got 1GB down). And I couldn't resume it, so had to wait another hour for it to re-dld it.
    Is very buggy and crashes alot. I can`t do a decent 5min browse without it going down.
    I switched to Chrome, which is much more stable.
  16. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    you guys should try the 64 bit version of IE in vista.. it's just like opening a window- just most of the plugins today are still 32-bit =\ I use firefox here with pimpzilla- but if you write websites, IE can be a pain in the ass as it displays things differently.. the only other one you really have to worry about is safari.. usually write for gecko browsers then come back and put in any extra for IE
    java performance.. I used to do some java years back- but mainly flash nowdays.. runescape is java =] it runs fullscreen too anfy rolled over twice off his fat wife when he saw those guys in the uk write that :D
  17. ssj12
    ssj12 Minimodder
    12 Sep 2007
    why was FF3.1b1 used when FF3.1b2 has been out for a while?
Tags: Add Tags
