Other If I had $6420 that had to be spent on a PC
Discussion in 'Hardware' started by TheMusician, 13 Sep 2009.
  1. TheMusician
    TheMusician Audio/Tech Enthusiast/Historian
    13 Jul 2009
    If I had $6420 that had to be spent on a PC. Regardless of if anything is a terrible deal or not (such as the RAM)
    In short:
    Core i7 975
    EVGA 141-BL-E769-A1 X58(4x PCI-E 2.0 x16)
    24GB Kingston DDR3-1600
    3 x EVGA GTX285 1GB (3GB VRAM total)
    2 x WD 1TB 7200RPM (2TB total or 1TB in RAID 1)
    ASUS Xonar D2X 7.1
    Hauppauge WinTV-HVR 1800
    XCLIO Windtunnel Full Tower
    Procrastination is fun.
  2. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    No SSD's?
  3. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Pfft, you could use your money way better than that.
    Get a dual-CPU workstation with a decetly priced graphics card, NOT a card that costs a grand.
    Oh, and you could use MS Paint or Paint.NET, or even buy Photoshop instead of using a warez version if you had that kind of money. :p
  4. bagman
    bagman Minimodder
    18 Apr 2009
    you got no 9800gt for the phyx's and you forgot the power supply!!!
  5. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    But he's got 3 of the 285s:D
  6. bagman
    bagman Minimodder
    18 Apr 2009
    so it still isn't the ultamate set up and i would have chosen 2 asus mars so you have 4 285's
  7. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    285 > 9800
  8. Rkiver
    Rkiver Cybernetic Spine
    23 Apr 2009
    $6k and that's the best you can do, and you managed to forget a power supply?
    For shame.
  9. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    6000 dollars has nothing on 6000 pounds.. Wheres the full system watercooling anyway?
  10. smc8788
    smc8788 Multimodder
    23 Apr 2009
    I honestly can't believe you'd spend nearly half of that $6000 on RAM. The graphics card choices are the least of you worries when you're spending $2,400 on some overpriced memory. You really do pay through the nose for 4GB DIMMs - that's $400 per stick FFS!
    And to top it off you've only spent $110 on a cheap, tacky case. Where's the ATCS 840 and Lian-Li PC-P80?
  11. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    That is sort of weak sauce. I've seen threads where people routinely go over $20k creating "ultimate computers". They generally feature dual-socket motherboards with high-end Xeons, 3xGTX285 plus a PhysX card (or 2xMARS, actually...), as much RAM as can fit on the board, piles of SSDs paired with 24-channel RAID controllers, and assorted other overkill.
    Also, shocker, watercooling is weak when you have infinite money and can afford a continuous stream of liquid nitrogen.
  12. TheMusician
    13 Jul 2009
    LOLS.
    Good thing I only compiled this build out of fun.
    Whoops, forgot the power supply. LOL.
  13. docodine
    docodine killed a guy once
    10 Feb 2007
    Over $6000 budget and you choose an Xclio case?
    :wallbash:
    Elton likes this.
  14. Sh0cKeR
    21 Aug 2009
    You'd really want to keep refilling the ln2 pots every minute?, with your PC looking like a waste disposal site with all the ugly dull copper in the chassis. A 6k pc is even more pointless than a 3k one it seems...
  15. doggeh
    doggeh What's a Dremel?
    27 Apr 2009
    :eek: That is one truly FUGLY case!
  16. Elton
    23 Jan 2009
    I would rep this. But there was no need...
    I'll do it anyways.
    By the way, $6000 and I can tell you that I can make a god of a computer.
  17. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    I went a little over budget... and I am missing some things (Like a case, Blu-ray player, storage drives, watercooling components....)
    Plus, I am not sure how much SLI support that board has. Tyan only lists SLI enabled for two high end Quadro cards and not for anything else. That may just have been what they were testing with though.
    Laz
  18. sheninat0r
    28 May 2007
    Infinite budget means no regard to practicality :D. Of course, with "only" $6000 to throw around I'd go for a chiller or chilled water cooling.
  19. bassboi72
    bassboi72 My dremel is broken.
    21 Jul 2003
  20. Von Lazuli
    23 Oct 2008
    One flaw, but it is a very very nice fileserver build... I couldn't quite justify such a monster RAID card on my one...
    The i7 975 only has one QPI link, meaning it won't work in a dual processor config. You need to go with a Xeon 5400 or 5500 series instead.
