Development iFrame not fitting in DIV
Discussion in 'Software' started by TheMusician, 7 Oct 2009.
  1. TheMusician
    TheMusician Audio/Tech Enthusiast/Historian
    13 Jul 2009
    Hi,
    I'm working on this page, and I can't seem to size the iframe properly. I set it to 80px, yet it's much wider than that, and it's falling off of the div. Here is the CSS page.
    Also, I was wondering how I can open multiple pages with one link with multiple targets (For example, that iframe as well as the main browser window)
    Any help would be highly appreciate it. I would be nothing short of grateful.
  2. FuzzyOne
    FuzzyOne
    19 Sep 2002
    Code:
    style="width: 80px"
    Is there a reason your using iFrames?, if you give us a run down of what you want to achieve there may be better solutions.
  3. TheMusician
    13 Jul 2009
    Okie doke. I want to be able to display another page in a little window/box in the right-side bar.
    These little pages will contain simple text. I want it all to fit into the little window.
  4. Shuriken
    Shuriken same christmas AV for a whole year
    1 Jan 2003
    Hey dude, you got the syntax wrong, you either need to do:
    PHP:
     <iframe name="LandmarkBox" src="Page.html" width="80px" border="0" ></iframe>
    Or: (and this is the prefered method)
    PHP:
     <iframe name="LandmarkBox" src="Page.html" style="width:80px" border="0" ></iframe>
    The first method is depreciated now, especially as you've defined the document as XHTML, so use the second. Also you have to specify units (px)
    Hope that helps
    TheMusician likes this.
  5. TheMusician
    13 Jul 2009
    Thank you so much! It worked.
