Modding Illuminate your PC - Part 1
Discussion in 'Article Discussion' started by brumgrunt, 2 Feb 2012.
  1. Zurechial
    Zurechial Elitist
    21 Mar 2007
    This is the bit-tech we've missed. Absolutely delighted to see an article like this on the front page again, thanks for listening to the feedback guys.
    As the others said: More please!
  2. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    Top stuff.
  3. TeeJay88
    TeeJay88 Whens the Damn Zombie Apocolypse
    9 May 2009
    What about using illuminated plexiglass. Installing leds into the side of a plexiglass window by drilling holes into the side of plexiglass and installing leds into these holes.
  4. longweight
    7 May 2011
    That only works if you have an etching on the plexiglass, it will look good if you do!
  5. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    Applause! Viva modding articles!
  6. S1W1
    S1W1 Minimodder
    25 Mar 2011
    Very nice stuff BT, more focus on modding (preferably without abandoning the hardware and gaming sides of things) would be great :D
  7. Big Elf
    23 Apr 2009
    Hoping to pick up some good ideas with this. At the moment the lighting in my case makes it look like a Jukebox.
  8. feathers
    feathers Minimodder
    11 Apr 2009
    This is so freaking f*cking awesome I just can't f*cking describe how f*cking awesome this is! I want bit tech to stop reviewing games and computer hardware and just do light mod features that's how freaking excited I am! Can you tell I'm really hyped up and very excited now? This goes way beyond the high I had when I tripped on mushrooms. It's just the most freaking fcking awesomest thing ever and I want bit tech to show pretty lights every day. This is so awesome I want to mod my X52 Pro as well, maybe add some green lights and an LCD showing temperature, time of day and other stuff.
  9. feathers
    feathers Minimodder
    11 Apr 2009
  10. Combatus
    16 Feb 2009
  11. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Where can you get the LED flexi chains? (the ones with rubber boots things).
  12. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    Is this bit-tech bringing back some of what many missed of old bit-tech which I wasn't around to see?. :D
    If it is which I think it is combined with all the rest of what bit-tech brings tech news/previews/reviews/gaming then things are looking saaaweeeeeet as I had a feeling they would be. :rock::D
    Just don't go mistreating the awesome staff you have whoever runs things. :nono::D They all rock & keep things running awesome. :clap:
  14. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
  15. Pirra
    Pirra What's a Dremel?
    7 Nov 2009
    Nice Article Bit-tech.
    I really like your guide like this one. Keep goin' with this.
    Regards
  16. andy_mcp1
    andy_mcp1 I may have an I.D-10T error...
    14 Jul 2010
  17. jon
    jon Chief Phrenologist
    26 Aug 2009
    UV lighting. It's subtle, and won't glare through the room when you're sleeping.
    Also, mount a switch to the side of your case that runs between the power source and the light, and it's easy enough to kill any light source you install.
  18. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    Hey chaps (and chapesses), don't only be restricted to illuminating your cases, you should see what I've done to an old pair of Y-Fronts I found in our lasses drawers. Hang on a minute.......
  19. PaulInGermany
    PaulInGermany What's a Dremel?
    1 Feb 2012
    Here's a ighting mod I made in a HAF 932 case. It's subtle and easily defeated by tuning the internal software volume down a bit. Uses a direct audio connection, not those electret-mic based sound modules.
    It's comprised of two main mods: glow under the motherboard and a hardware-hacked TB Apollish 140mm.
    http://www.youtube.com/watch?v=4zWugKPG0Aw
  20. PaulInGermany
    1 Feb 2012
    That's not entirely true. The acrylic will need some soft of surface disruption for it to emit electons, but it can be as simple as roughing the surface lightly with sandpaper. Otherwise, you'll get a very sharp edge of light at the exterior edge of the acrylic, which is itself a very nice effect.
    An edge-lit acrylic mod in a HAF 932 case with lightly sanded edges:
Tags: Add Tags
