i really want a pink illuminated mouse pad ... anyone know where to get one or anyone willing to make one for me (i would try, but lack of time)
try a froogle search. first result: http://www.cafepress.com/muses_daydream.20747430?r=froogle not sure if its what your looking for, though. the title sounds kinda wrong...
nah i want it to illuminate pink.. ala .. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=75520&item=5203153896&rd=1&ssPageName=WDVW but it is not pink
A pink alluminated plexiglass mouse pad... Going to have to be done by hand with some red and white LEDs most likely; Id do it for you, but Im in the USA.
Itd only take you a few hours tops. the question is, is it worth the price of LEDs and resistors and whatnot. also, how will it be powered, being as its out of the case, so unless you rigged a molex connector some really long wires and had it coming out from that, youll need to think of power for it.
lol, thats why i just want to buy one .. plug it into usb and whack (at the moment ... i dont really have 2 hours spare anywhere)
http://www.theglowcompany.co.uk/acatalog/GLOW_MOUSE_PADS.html Will this do? It looks a bit purple, but this is probably the closest you'll find without building your own. Also, this one is cool because you can change the colors .
Google for "electroluminscent pink sheet". It's somewhere out there because I saw it before used for brake pedals. Here is a link for string: http://hrg.ebigchina.com/sdp/182281/4/pd-1011914/375597-507266.html
