Improved PPD by enabling beta work units.
Discussion in 'bit-tech Folding Team' started by Tattysnuc, 24 Nov 2012.
  1. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    I came across a thread on another site (OCUK) alluding to some benefits with enabling beta work units. Now, I'm not of the beta plan, but I'm certainly going to look into it if this is the sort of "benefit" that they get periodically.
    http://forums.overclockers.co.uk/showthread.php?t=18459693
    If it's as simple as this to get improved ppd on fermi+ cards, then that's got to be a good thing... right?
    I'll post back wiht my results. At the moment I've been rebuilding the OS due to an SSd failure in my my Raid0 OS array. :( so No overclocks in Windows, only throught he bios (4.2Ghz on CPU, stock on GTX 480's)
  2. Tattysnuc
    19 Jul 2009
  3. Tattysnuc
    19 Jul 2009
    Am currently processing an 8054 WU on each GTX 480 GPU. Will report back when I see anything different....
  4. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    Tatty, I think if you look on the official forum, there is a beta trial underway for P8057 only. This is to look at 'equalising' the points for GPU's with respect to CPU's, and using the QRB. If you go down this route (and F@H would prefer only 'beta testers' to do so), you may not receive any of these specific WU's, and you will get other beta WU's, which, by their nature, may either be duff WU's and not fold to produce any credit or may have poorly set credit levels. Just something to bear in mind ....
  5. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
    ive just picked up WU 8057 :D
    will post when its done a few % with the pdd :)
    EDIT:
    OMG :jawdrop::jawdrop:
    WU: 8057
    TPF: 2.06
    Base Credit: 2549
    Credit: 18230
    PPD: 125000 :jawdrop:
    Thats with a GTX560 non Ti
    Hmmmm its not picking up the core in HFM
  6. kirk46
    9 Jun 2012
    guys im getting loads of these beta WU's on the GPU at 125k ppd :eek:
    set your client up!! :D
  7. Slowlemon
    Slowlemon What's a Dremel?
    17 Apr 2012
    Hi All
    I tried this last weekend but only got P8018 work units and most of those crashed. I am using client V7.1.52, do you need the new version to get the P8057 work units? I have 2 off GTX560ti, it costs a lot of electric to run them but with QRB it would be well worth it.
  8. kirk46
    9 Jun 2012
    i didnt update my client slowlemon...
    i just used the guides :)
    at first i did get 8018 WU's then started getting 8057 WU you don't get them all the time but since then only the odd one or 2 are not the beta one...
    if its crashing back off the OC on the GPU :)
  9. StreetSam
    StreetSam Minimodder
    30 Aug 2005
    I've just turned on my; 6x 460 and 10x 450 to take advantage of these bonuses
  10. kirk46
    9 Jun 2012
    good man :D
    i just bought 3 GTX480's for this :D
  11. cave_diver
    cave_diver Minimodder
    19 Jan 2011
    House needs thawing out does it? :jawdrop:
  12. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    OK, so what's the trick to get these?
    I'm running v6.3 client, with -betateam flag, my key, and get nothing but ordinary WUs :sigh:
  13. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    These still working for you? Wondering if I am too late to the party.
  14. kirk46
    9 Jun 2012
    im sure they have gone for now.....
    there are some 807* ones tho which are under the beta flag i believe
    but all ive had today are 8054 :(
