Windows In the event of catastrophe (touch wood)
Discussion in 'Software' started by ModSquid, 11 Jul 2013.
  1. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Just a quickie, chaps - whenever I set up a new install I move the users, prog files and progdata folders to the D: drive on the basis that should I need to reinstall Windows, I can do so over the C: drive without losing any data or settings.
    A thought just occurred to me though - if I did have to do this and followed the process through, deleting the above new folders from C: (and obviously reinputting the junctions etc. as prior), would everything still work, given the untouched, older folders on D: might be referencing a different registry?
    And so, is there any point in moving everythng over to D: at all? A lot can be found online espousing the benefits but it seems moot if nothing will work again afterwards.
    Thanks in advance!
  2. kenco_uk
    28 Nov 2003
    The only things I back up are either pst/nk2 files (or dbx/wab) and the profile desktop/documents/favourites folders and possibly any stray files/folders on the root.
    I think you're right in that, if you were to restore, you'd have to reinstall programs anyway as they create registry entries.
  3. ModSquid
    16 Apr 2011
    Hmm...interesting. And thanks for getting back!
    I do backups using DriveImage XML (and might be switching to Acronis once I've tested it out), so I'm not too fussed about being able to restore from those. However, I do worry about what happens if I need to reinstall in the event of one of the images containing any issue ie. if a problem went unnoticed and any re-imaging just brought the problem back again.
    Or, as happened recently, I upgraded from XP to 7 and had to do a completely clean install. Then it's a chore to reload all the programs (but it sounds like I might have to anyway).
