Hi guys, This one is going to be a little different. I've decided to post a build log for this build however the build has been finished now for a few months. This was done around March this year when I was still in the middle of my move. I had to get this build done along with another for an event. With the move and rushing to get it finished for the event I didn't have time for a build log. For those interested to see I will get all the content out for this fairly fast Hope you guys enjoy this one. I have to say the In Win H-Frame 2.0 is a stunning looking case. SPECS: Case – In Win H-Frame 2.0 Motherboard – ASUS Maximus VIII Formula CPU – Intel i7 6700K Memory – 4 x 4GB Kingston HyperX Predator DDR4 GPU – 2x NVIDIA GTX 980 Reference Model SSD – 2x Kingston HyperX Savage 240GB SSDs PSU – In Win 1065W PSU Cables – Icemodz Fully Custom Individually Sleeved Cables LEDs – Icemodz RGB LED Strips Radiators – 240mm and 360mm Bitspower Leviathan Slim 360 Radiator Fans – 6 x NoiseBlocker PL1 fans Pump – Bitspower DDC Plus Reservoir – Bitspower DDC TOP Water Tank Integrated Kit 150 with upgraded True Brass end caps Fittings – Various Bitspower True Brass Fittings Tubing – Bitspower Crystal Link 12mm acrylic tubing CPU Block – Bitspower CPU Block Summit EF Ice Black GPU Block – 2x Bitspower VG-NGTX980 Acrylic Top with Stainless Panel (Clear) Coolant - Clear - distilled water with a silver kill coil Thanks for checking it out! Cheers, Alex
Hi guys, Here's another quick update of lighting features on the case Both the case lights as well as the PSU light can be turned off individually. Thanks for checking it out! I apologise for the quality in some of these photos, like I said before this was all done in the middle of my move Cheers, Alex
Hi guys, The theme for this build which I forgot to mention will be a bit art deco with some gold vinyl. Here are the side panels You can see in the background how this was during my move haha This is the back side panel featuring the sponsor logos. Thanks for checking it out! Cheers, Alex
Hi guys, Here's a quick look at some of the components going in. Firstly, the ASUS ROG Maximus VIII Formula and the CPU in it is the 6700K. GPUs going in are two reference GTX 980s which will of course have waterblocks installed however I've always loved the look of reference cards. Two 240GB HyperX Savage SSDs 16GB of HyperX Predator DDR4 And lots of Bitspower watercooling gear! When this arrived at the time it was watercooling gear for two builds hehehe. And despite the look of that bottom box, everything was in one piece. Thanks for checking it out guys and stay tuned for more. Cheers, Alex
Hi guys, Here is the vinyl work I did on the SSDs and HDDs going into this build Thanks for checking it out, Cheers, Alex
Hi guys, I've done a bit of vinyl work on the graphics card waterblocks as well, check it out and the build is nearly done in these pics Thanks for checking it out! Cheers, Alex
Hi guys, I have all the cables in here and you can see some of the vinyl work done on the radiators as well as the In Win logo on the fans. The only mod done to the case and even that has been super simple to do is the front radiator mount which is just done with a large L bracket to hold it up. With the pump/res combo attached to it with a Bitspower X bracket and res holders. You also get a glimpse at the Bitspower True Brass fittings which will be used throughout the build. Another thing to note with the cables is that the 24pin didn't actually end up working. Given that the PSU in this case is unique and has it's own form factor to suit the case, meaning that it is much larger. The pin-out must have been very different. The cables came from Icemodz and it was the first time they did cables for this PSU. Without actually having the PSU there to inspect, it was a bit of guess work involved. The build was then needed for an event so there was no time to order another cable therefore the stock 24pin cable was used throughout the build. It doesn't look bad but not as nice as the custom one. Anyways, enjoy the pics. Thanks for checking it out! Cheers, Alex
Hi guys, Here are photos of the finished system. These were taken at a LAN Party back in March of this year where the build was first on display. Hope you enjoy. I will have more photos up shorty. Thanks for checking it out! Cheers, Alex
