Scratch Build – In Progress In Win Wood-Frame
Discussion in 'Project Logs' started by Bogdan, 15 May 2016.
  1. Bogdan
    Bogdan Member
    4 May 2016
    Hi everyone, here is my first scratch build!
    The case is inspired by In Win's D-Frame Mini.
    I would like to thank my sponsors: In Win Nederland , Aquatuning Europe, Antec Europe, MSI Europe,Patriot Memory and Noiseblocker.
    As I've said, the case is based on the D-Frame and D-Frame Mini, it is made using fir wood beams and planks.
    Now the sponsorships
    Aquatuning
    MSI, Antec, Patriot and Noiseblocker
    Here is how the sides of the case look like before gluing:
    The case after gluing, I had to use screws to reinforce the frame.
    The "Wood-Frame" after gluing, sanding and painting:
    The components
    MSI's Z170A XPower Titanium Edition
  2. Bogdan
    Bogdan Member
    4 May 2016
    The GPU used on this project is a GTX 650 ti, the TwinFrozr III cooler matches the Titanium motherboard :)
    Here is one amazing Power Supply from Antec!
    The next update is coming fast!
  3. Cheapskate
    13 May 2007
    If you don't make a wicker fan grill for this I will be extremely upset.
  4. Bogdan
    Bogdan Member
    4 May 2016
    Update: I finished installing all the trays for the Power Supply, pump and motherboard.
  5. Bogdan
    Bogdan Member
    4 May 2016
    Update :D
    I mounted the motherboard and CPU block, and made a stand for the 240mm radiator using two square metal beams.
  6. sethnmalice
    sethnmalice New Member
    21 Jul 2007
    Looks good, what timber are you using?
  7. Bogdan
    Bogdan Member
    4 May 2016
    I'm glad you like it!
    I used spruce wood, I live in a mountain area so this wood was available :D
  8. Mosquito
    Mosquito Active Member
    24 Mar 2011
    Interesting so far, too bad about all the screws :p
  9. Bogdan
    Bogdan Member
    4 May 2016
    What do you mean with the screws?
  10. eucalyptus
    eucalyptus I am 19 and Swedish!
    29 Sep 2015
    Just to make clear, you basically made your own copy of the D-frame in wood??? WOW! Impressive work! I love the color, how did you make it? :)
    *following*
  11. eucalyptus
    29 Sep 2015
    The frame is so clean, but all the modern screws isn't really discrete, I think that is what he means :) They sort of break the pattern :p :)
  12. Bogdan
    Bogdan Member
    4 May 2016
    Pretty much, the overall shape is based on the D-Frame Mini while the actual size of the case is more or less the size of the D-Frame.
    The dark color is due to the lacquer used, there are two coats on the case.
  13. Bogdan
    Bogdan Member
    4 May 2016
    I know, but I don't trust adhesive, so screws for the trays especially for the motherboard tray.
  14. Bogdan
    Bogdan Member
    4 May 2016
    Update: The Power Supply is fitted to the rest of the system, the Antec HCP Platinum is one of the best :)
    , this one is the 850W variant.
  15. Bogdan
    Bogdan Member
    4 May 2016
    Almost the final update - mounted the reservoir and now filling the loop :)
    Unfortunately one of my two Graphics Cards got water all over it so this project unfortunately will not feature a GPU.
