Infra Red serial port kit
Discussion in 'Hardware' started by Bursar, 18 Nov 2002.
  1. Bursar
    Bursar What's a Dremel?
    6 May 2001
    Does such a device exist?
    Here is the dream device I'm after :D
    Comes in two parts. One part connects to the serial port on the back of the PC, and the other connects to the serial port on the device.
    Both parts are capable of sending and receiving data (so for instance, you could hook up a modem using it).
    Would support upto 115.2 K/bits.
    Perferably it doesn't require any tricky software to use, but drivers for XP are fine.
    Range isn't much of a problem, I'd be able to provide it with line of sight between the two halves, and they'd be no more than a couple of feet apart.
    So, does anyone know of a product that provides those features? I've been seraching on Google, but haven't come up with much.
    I'm an electronics novice, so I think building such a device would be beyond me, but if the parts were cheap enough and the instructions clear enough, I could be tempted to give it a go.
    Cheers.
  2. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    I would ask Meblin about this
  3. Meblin
    Meblin Supposed IR God!
    5 Mar 2002
    Will comment later when I have a second :D
    Meblin
  4. Bursar
    6 May 2001
    Woohoo! :D Does this mean you know of a device that does the trick?
  5. Meblin
    5 Mar 2002
    Well maybe :naughty:
    You can put an IrDA connector on your motherboard (if it supports IrDA) and it will talk to other IR devices such as mobile phones, other computers, etc...
    I'm not sure of the data transfer rate but don't think it's as fast as you are looking for.
    If you use IrDA you don't need any other software. What is the second device?
    I haven't seen a serial device that can do this, but that doesn't mean there aren't any. Bluetooth may be a device that may work.
    Meblin
  6. Bursar
    6 May 2001
    OK, well the plan was to hook up an external LCD screen to the IR kit.
    By sticking an IR module on the back of the LCD and running it with a few batteries, I could make it wireless.
    I guess it would be fine running at 9600, but I need an IR module that will connect to the PC and the LCD, and run communications in both directions between the screen and the PC.
    That's the bit I'm having trouble with. Most of the IR things I've seen for PCs are really just receivers (so they'll accpet signals from a remote control). I need the PC end to send commands to the screen.
    Any advice on doing this?
  7. Meblin
    5 Mar 2002
    What motherboard do you have and where are you located?
    I make IrDA connectors and as long as there is a signal present then the PC will pick it up. The problem you will get will be getting software to use it.
    What's the LCD?
    Meblin
  8. Bursar
    6 May 2001
    I'm in the UK, and I have an Intel D850EMV2. I don't currently have the LCD, as I'm planning and saving for the mod at the moment. I'm thinking of getting the Matrix Orbital LCD2041-WB, or possibly the LCD2041-WB-V.
    I was planning on using LCDC to control the LCD.
    At the moment all I really need to know is if it's possible. If it's not going to work, then I'll go for a wired solution.
  9. Meblin
    5 Mar 2002
    I'll look on the Matrix orbital site and talk to Mat-d-Rat about LCDC
    Meblin
  10. Meblin
    5 Mar 2002
    Well your mb doesn't have IrDA connector so that is out of the question.
    I have looked at the LCD and now know your plan. One thing that you will need to consider is that the LCD needs a 5V or 12V supply. I'm not sure how long batteries would last to power it though. Next I make IR remote control kits for the serial ports but they can only receive data. They use the data carry pin as a power supply but I don't think this would work with the IrDA type sensors. You would aldo need a power supply for the IR sensor at the LCD end.
    I think this is a mamouth task and I wish you luck :p
    Meblin
  11. ZapWizard
    19 Sep 2002
  12. Meblin
    5 Mar 2002
    That's the part that I use for my IrDA connector. I haven't tried to see if it will work on a serial connector as I haven't contemplated using it like that before.
    A serial port is as follows:
    Code:
       1 2 3 4 5       1 DCD (Data Carrier Detect)    5 Ground
       o o o o o       2 RXD# (Receive Data)          6 DSR (Data Set Ready)
        o o o o        3 TXD# (Transmit Data)         7 RTS (Request to Send)
        6 7 8 9        4 DTR (Data Terminal Ready)    8 CTS (Clear to Send)
                                            9 RI (Ring Indicator)
    Pin 2 would connect to RxD
    Pin 3 to TxD
    You would then need a 5V supply at either end and the other components. I don't think JP1 is necessary except to fine tune. I have never put it into my IrDA connectors and they work fine.
    You can get the components from RS. The most expensive part is the sensor (about £2.60ish each). The other parts ar relativly cheap at about 20p max for 10.
    R1 is a 13 ohm 0.25W+ resistor, R2 is a 47 ohm 0.125W resistor, C1 is a 4.7 µF tantalum capacitor and C2 is a 0.1 µF ceramic capacitor.
    I might give it a go, but then I did fry my last LCD :( so I might leave it to someone else to play with :hehe:
    Meblin
  13. Bursar
    6 May 2001
    This sounds like it's getting really complicated (for my brain anyway :p).
    I think I'll just have to bite the bullet and go for a wired solution.
