Windows Install Order?
Discussion in 'Software' started by crazydeep74, 2 Jun 2007.
  1. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    I want to put windows 98se, NT4, and 2000 SP4 on a single 60GB hard disk in a laptop. What order should these be installed to allow multi boot?
    I figured 98se first, then NT, then 2000? They will be on separate 8GB partitions.
  2. identikit
    identikit Minimodder
    5 Jun 2004
    In my experience with 98se and XP in dual boot, 98se first then XP. So I guess the order you're using would work the best.
  3. Veles
    Veles DUR HUR
    18 Nov 2005
    Start with the earliest windows first, thats usually the best way.
  4. dimebar
    dimebar What's a Dremel?
    26 Jul 2003
    in the case of vista duall boot is a nightmare if you do not install the oldest OS first.
  5. krimson
    krimson What's a Dremel?
    16 Nov 2006
    yeah, a good rule of thumb is to always do oldest to newest.. the newer ones will find the older ones, and set up the boot loader accordingly..
    and, if you plan in incorporating linux, a good rule of thumb is to install linux AFTER all your windows OSes are installed
