News Intel’s vision for ray tracing exposed
Discussion in 'Article Discussion' started by Guest-16, 3 Apr 2008.
  1. Guest-16
    Guest-16 Guest
  2. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    What are the realistic timescales before we see a mainstream graphics chipset capable of raytracing, or even a hybrid raster/ray tracer? Is it likely to be within the next decade, or are we talking long-term research here?
  3. TreeDude
    TreeDude What's a Dremel?
    12 May 2007
    Well more creative freedom is great. But it also means much more work must done in order to get the desired result. This is why OpenGL is not used as much as DirectX. It requires more time and effort to get what you want. But OpenGL is more robust and allows for more creative freedom than DirectX (plus you can still use DX along with OpenGL).
    I don't see ray tracing taking over as the main way to create games any time soon. I think within the coming years we will see the big budget games start using it though. Maybe Crysis 2.....
  4. johnmustrule
    johnmustrule What's a Dremel?
    12 Jan 2006
    Although I know it's not a very good comparison, the image quality in 3ds max when using ray tracing is simply so much higher than alternatives it's always been worth it to me to wait a week for a scene to render vs just a day.
  5. zero0ne
    zero0ne Minimodder
    19 Jul 2004
    in 5 years we will have processors that are clocked at ~30GHz going by moores law (doubling every 18 months, so 3.3 cycles of doubling with a start point of 3Ghz)
    Of course this will probably be slowed down since the major companies are looking less towards clock speed and more towards multi core processors.
    in 20 years we will have a quantum computer (since moores law will be failing us at about this point; quantum mechanics easily proves that this WILL happen), and in 50, that quantum computer could theoretically run at the speed our brain does. (of course our brain is a "learning neural network" and trying to simulate it will probably not happen)
    check out "michio kaku" for more about these farther reach points I made, He is one of the better Geniuses of our time, since he is able to gracefully explain all these crazy topics in laymen's terms. (and don't confuse crazy with not-true, every idea of his is coming from one research paper or another about quantum mechanics, string theory, etc etc)
  6. wyx087
    wyx087 Multimodder
    15 Aug 2007
    so, in about 10 years time, we'll probably have to cough out lots money for a ray-tracing CPU to play ray-tracing games smoothly, while also pay through the nose for nVidia's monster graphics card to play traditionally programmed games properly?
  7. TreeDude
    12 May 2007
    By that logic we should already have 5ghz+ CPUs. Yet we do not. Speed isn't everything. Efficiency means a lot more.
  8. knyghtryda
    knyghtryda What's a Dremel?
    2 Jan 2006
    Number 1 misconception about moore's law. It has NOTHING to do with speed. The original Moore's law is that the density of processors will double every 18 months. By doubling density one can normally get ~2x in performance, but that doesn't mean clock speed/memory speed/any speed will go up during that process.
    As for ray tracing... a hybrid render path would be interesting (more realistic reflections, shadows, and particles comes to mind), but remember, games like Crysis are still currently very CPU bound as well as graphics bound, so speeds are going to need to increase significantly in order to really utilize this hybrid render path.
  9. Flibblebot
    19 Apr 2005
    Moore's law doesn't say anything about speed, it's about the number of transistors on similar sized chips. Moore's law states that the number of transistors on a similar sized chip will double roughly every 18 months.
    But it's not a law in the strict scientific sense, it's more of an observation.
    EDIT:
    Damn, got there before me!
    Not necessarily true. The trend for processors at the moment is towards multiple cores, so it's not inconceivable to image CPUs with 8 or 16 cores within the next 5 years or so. If that's the case, you could quite easily use one or more of those cores solely for managing your render path.
    Parallelism Cheesecake :D
  10. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=3276 table on the first page here shows that quite nicely
    original pentium: 3.1m transistors and 294mm^2
    penryn: 410m and 107mm^2
  11. wyx087
    wyx087 Multimodder
    15 Aug 2007
    Moore's Law is a marketing tool generated by Intel, Intel put the 18 month there. all Moore did was made a very, very rough observation, Intel marketing people did the rest.
    (IET magazine and Wiki both agree on this)
  12. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    [sarcasm] Didn't you know? By then PC gaming will be dead and it'll all be console-based droll. [/sarcasm]
    :rolleyes: :hehe:
  13. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    This is a good idea if it can be made to work well - imagine graphics cards with arrays of raycasting processors rather than stream processors.
    The DirectX/openGL triangle renderers are very lovely, but the only reason they look as good as they do is that they've had an awful lot of work put into a limited number of goals, and that's why computer games are all starting to look the same. I can't be the only person around who remembers the variety of gaming that was available on the Amiga, from top down to side scrollers to platform games and even the beginnings of first-person shooters, it went on and on. These days you have FPS or FPS and they all have the same effects and tricks because that's what the systems will do.
    In short they aren't very general. Every time someone wanted to do effect X, be it refraction or anisotropics or glows or whatever, they put in an extension for it. You can't do anything that someone else hasn't thought of. Everything's basically being faked, and there's a million examples of how you can make that rather obvious. The best one that comes to mind is the stack-o-planes effect you can get when smoke intersects other geometry. DX10 tries to solve this and is partially successful, but it's a hack on top of a hack to try and get away with not really doing it properly in the first place. I think you would certainly get less of these sorts of glitches - depth sorting problems with distant objects, intersection issues - with a raytracer.
    If Intel are saying that this is not the way to go in the future, I fully agree with them.
    P
Tags: Add Tags
