So I've seen this popping up all over the place. Same spec as the Linx 7/8/10 tablets that are floating about at the moment. Quad core Atom 2GB RAM 16/32GB EMMC Windows 8.1 32bit + Android (dual boot) Recon its worth a punt? I've seen them as cheap as £64.99 inc snail mail from China. Would make a fantastic media player : D
There is this too : http://hexus.net/tech/news/systems/78721-guleek-i8-tiny-windows-81-pc-built-in-battery/ I want a device exactly like this to run some linux stuff on - the only think I would want as well is a real ethernet port. I still think the device I want doesn't exist Doesn't seem that it's obviously easy to stick linux on these, I would give up the ethernet port if I knew I could run linux on it. I need to refresh my monitoring network and running the linux remote machines on these would be absolutely perfect.
From what I've gathered it must be powered by usb tho I can't get proper confirmation on that. If so then its only getting around 2W of power. Likely the atom is downclocked if there is memory ram and bluetooth to power.
Sweet! Im curious to see if they would drive all the digital signage at work. Should be lightning fast with a lite distro.
Ok, I can finish my ultra low power mechanical Keyputer now for my DIY electronic hobbies and everyday general purpose ! Can't wait.
