News Intel confirms Meltdown while Spectre hits everyone
Discussion in 'Article Discussion' started by bit-tech, 4 Jan 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    I guess AMDs' "it not AMD then apply PTI" patch for the linux kernel was rejected then?
    Even if AMDs and ARMs are only affected by one vulnerability, there's only one way to protect end users from it, correct?
  3. Gareth Halfacree
    4 Dec 2007
    That patch is only for Meltdown, as I understand it.
  4. Hustler
    Hustler Minimodder
    8 Aug 2005
    I bet this will annoy the security services, they've probably been using it for years to get in to places they shouldn't have been...
    GravitySmacked likes this.
  5. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
  6. Gareth Halfacree
    4 Dec 2007
    No, there's no danger: if the flag isn't set (because you either have no anti-virus installed or the anti-virus you have would break with the Meltdown patch applied) Windows Update will run fine but not offer you the patch (leaving you vulnerable); the patch will only appear in Windows Update if the registry entry is present.
    Aterius Gmork likes this.
  7. tristanperry
    tristanperry Minimodder
    22 May 2010
    This feels like a biggie (to probably state the obvious).
    https://www.phoronix.com/scan.php?page=article&item=linux-415-x86pti&num=2 - pre and post patch benchmarks showing some fairly big performance decreases (in certain CPUs, in certain cases)
    https://aws.amazon.com/security/security-bulletins/AWS-2018-013/ - AWS have been rolling out mandatory reboots of affected instances
    https://www.react-etc.net/entry/exploiting-speculative-execution-meltdown-spectre-via-javascript - a possible Javascript exploit for this (potentially allowing websites to read your memory?)
  8. loftie
    loftie Multimodder
    14 Feb 2009
    WRT the antivirus, does that only include 3rd party software or does Windows Defender add the reg entry?
  9. Gareth Halfacree
    4 Dec 2007
    Windows Defender adds the registry entry: Microsoft's official solution to the patch not rolling out to Windows Server installations is to install Windows Defender on 'em first.
  10. loftie
    loftie Multimodder
    14 Feb 2009
    OK, ta. Was expecting it not to :p
  11. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    So I can see why this is a huge problem for virtualized servers, shared hosting and the like, but what's the risk to the average desktop user? Is it more to do with how leaked kernel memory can form the basis of further attacks or is there something else of value in kernel memory?
  12. Gareth Halfacree
    4 Dec 2007
    In the other thread in Hardware I posted a demo of a password being stolen by a user space application as it was being typed - and, remember, this is exploitable through the browser. Serious stuff.
    MLyons likes this.
  13. wolfticket
    19 Apr 2008
  14. Anfield
    Anfield Multimodder
    15 Jan 2010
    Speculative execution of code across VM boundaries, I wouldn't want to be a Microsoft Azure PR rep:lol:
  15. Guest-16
    Guest-16 Guest
    Yea no one is gonna turn off Javascript. Every site relies on it.
    Plus it's not just a single exploit. This is a new category that exploits the fundamental performance enhancement of speculative OoO execution in EVERY ISA, not just x86: MIPS, SPARC, zPOWER, POWER etc - all affected by Spectre style attack. Pandora's box.
    On the flip side if you're a distopian authoritarian government, make money from selling people's private details or in infosec, good times!
  16. jb0
    jb0 Minimodder
    8 Apr 2012
    Yeah, my understanding is it makes friggin' Heartbleed look like a niche issue.
  17. somidiot
    somidiot Minimodder
    18 Aug 2009
    Will you guys (bit-tech) be doing your own set of benchmarks on performance hits? From what I've read games and most things regular people do won't take that big a hit. Although I'm still curious about handbrake, video editing software and zip performance.
  18. adidan
    25 Mar 2009
    I caught the headline of the FT (I think) saying something along the lines of companies should upgrade all their hardware to be fully safe.
    But what is the go to 100% safe hardware option out there? Yes, i'd go AMD as they're least affected (that is no Meltdown) but that's still not 100% - will Ryzen 2 be and what of the next iteration of Intel's line?
  19. Gareth Halfacree
    4 Dec 2007
    Right now, if you want absolutely cast-iron 100% safe, your only option is to find a chip that doesn't include speculative execution - which ain't easy, considering everyone is using it to boost performance.
    Pre-1995 chips and selected Atoms are about your only option for the desktop right now. The Cortex-M family is safe, but not designed for desktop workloads. Most implementations of RISC-V are safe, too, but again we're talking off-the-shelf parts being designed for embedded use and running at 300MHz.
    If you fancy getting really clever, stick the RISC-V RocketChip design (which doesn't have speculative execution) on an expensive FPGA and see how far up you can crank the clocks, then shove Linux on there. 100% protection against Spectre!
    If you're stuck in the x86 ecosystem, though, you're SOL: anything you can buy now is vulnerable, and I'd be surprised if the next generation wasn't vulnerable too - trying to change the design at this late stage is going to be a right bugger.
    adidan likes this.
  20. adidan
    25 Mar 2009
    Speculative execution, hm, I should do more reading - from a naive pov shouldn't it be possible to allow speculative execution but have it so there are things you just can't speculate about unless specific conditions are met?
    That in itself is a bit of an IF question and i'm giving myself a meltdown. Best read up abit.
    Now I'm wishing I still had that BBC Model B and my copy of Elite :)
    I do have a netbook with an Atom in it, will have to check which one, now is perhaps the time to dig it out and put a distro on it.
    Just glad I held back on an upgrade, prefer tp be with a 3770 and not 100% safe than being out of pocket and not 100% safe.
    Hang on a minute, what about consoles - completely forgot about them, will have to check their cpus.
Tags: Add Tags
