News Intel confirms Skylake crash erratum
Discussion in 'Article Discussion' started by Gareth Halfacree, 11 Jan 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. David
    7 Apr 2009
    I wonder if their microcode fix will also slam the door on non-K overclocking...
  3. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    The only surprise is that this isn't more common. These things are complicated, and I'm sure that it's the ability to tweak the microcode (and a lot of attention to detail by clever people) that means we don't see these issues far more.
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I wonder if their "fix" is going to fix or just disable something.
  5. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    My Pentium says that figure should be $474.668m :p :D
    Sounds like a pretty esoteric bug if it's only showing up with extreme software like Prime95. Otherwise we'd have been none the wiser. As Phil says above, we probably don't know half the microcode fixes that are out there.
  6. Gareth Halfacree
    4 Dec 2007
    If you're curious, you can read all the errata in Intel's regular Specification Update publications. Here's the Skylake update from September last year (PDF warning), which lists 53 errata - all of which had no fix when the document was published.
  7. Alecto
    Alecto Minimodder
    20 Apr 2012
    My thoughts exactly.
  8. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    Having just upgraded to a Skylake system, and having a 'bleeding edge' system for the first time in my life, I find that this edge is kinda... sharp and sticky with what appears to be blood :eeek:
    As long as issues like these are getting fixed ASAP it's okay, I guess. There's a price one has to pay for using what basically amounts to hardware that's not been field-tested, though...
  9. azrael-
    azrael- I'm special...
    18 May 2008
    Actually, the FDIV bug was one of the primary motivators for Intel to support updatable microcode in its processors.
  10. DC74
    DC74 Doh!
    4 Jan 2011
    I have to agree with the comment wholeheartedly, having upgraded to a Skylake system myself a month ago and the only problem I've had so far is a badly coded driver from Logitech (Game panel Software) which seems to relate to the new Z170 chipset, though I can't help but wonder...
    Perhaps intel should spend some more time doing intensive testing with the software available to see what happens rather than being governed by release dates for their CPU's. The giveaway is in the name "Quality Control Testing" they should have picked this up and fixed it before release.
  11. Elledan
    4 Feb 2009
    It does make one wonder whether Intel shouldn't make standard stability testing tools like the one in the article part of the testing suite. Or rather, why the heck it isn't already.
    So far I had to flash the BIOS of my Asus mainboard to get some memory stability, then I had to replace the mounting of the CPU's HSF because it could bend the CPU's substrate. Now I'll have to flash the BIOS again to prevent hard lock-ups like this. I do hope this is the last issue, because it's getting somewhat silly.
