News Intel rumoured to restore soldered heatspreaders in Haswell-E
Discussion in 'Article Discussion' started by Gareth Halfacree, 28 Jul 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. faugusztin
    11 Aug 2008
    "smaller die sizes causing cracking of the solder" -> "Those issues appear to have been resolved in time for the Haswell-E enthusiast chip family".
    Well, the solution is probably the fact, that S2011 cores in general are damn big :D.
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    By the looks of the picture it seem they may have switched to epoxy.
  4. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    Looks like they ****ed that CPU when they de lidded it : /
  5. ZeDestructor
    ZeDestructor Minimodder
    24 Feb 2010
    Why would you think epoxy rather than straight solder?
    Based on Toppc@coolaler's Ivy-Bridge-E leak back in the day (http://www.coolaler.com/showthread.php/305405), the epoxy around the die looks very similar (identical if you ask me, and I've seen my fair share of bare dies on laptop chips...) to the Haswell-E core, so one would think straight solder rather than metallic epoxy, no?
    Mind you, Toppc seems to have used a heatgun of some sort to melt the solder rather than straight lid rip...
    Interestingly though, that looks like the 12-core die rather than the expected 8core die.. someone tore up a Xeon 12-core perhaps?
  6. azazel1024
    azazel1024 What's a Dremel?
    3 Jun 2010
    That'll buff right out.
  7. Corky42
    30 Oct 2012
    Nothing other than looking at the picture TBH, it just doesn't seem very solder'ie to me as it seems to lack the typical shine you would get from fresh solder. That and the way is looks around the edges of the die where it seems to me you can see the epoxy/solder in it's clean state and where it seems to have been pulled apart, to me it looks similar to an epoxy break than a solder break.
    In the end it's pure guess work on my behalf though :)
  8. ZeDestructor
    24 Feb 2010
    That would be easily explained by the fact they seem to have ripped the die from the PCB it's mounted on. The evidence lies in the relative height of the epoxy residue. Aside from being fused to the lid using solder or some other form of molecular-level bonding, I don't see how you can get epoxy that's strong enough to rip the die right off the underside contacts....
    I could be wrong, but judging by the epoxy breaking around the die solder-down location, the epoxy would have broken before the die got ripped out...
    Also, pay attention to the very shiny "overflow" of what seems to be solder on the bottom edge of the die on the lid...
  9. Corky42
    30 Oct 2012
    Epoxy is used in the aerospace industry so there is no doubt it can be very strong.
    Either way, solder or epoxy should be a big improvement on the thermal grease they've used previously.
    IDK how much difference thermally there is between the typically used solder and a good thermal epoxy.
  10. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    the shine is reminiscent of a high silver content solder
