CPU Intel to skip Ivy-e and go straight to Haswell-e?
Discussion in 'Hardware' started by phoenixck, 25 Jun 2013.
  1. phoenixck
    phoenixck What's a Dremel?
    7 Jan 2012
    I was speaking to a friend who works for a rival of Intel (in the mobile market) and we were discussing the new haswell releases. I expressed my surprise that ivy-e hadn't been released, and was informed that Intel were actually going straight to Haswell-e. Started looking around for articles to back this up and many seem to suggest a haswell-e q4 2013 or q1 2014 release, which wouldn't leave room for an ivy-e release.
    Take the above with a pinch of salt of course, but what do you guys think?
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
  3. Guest-16
    Guest-16 Guest
    In response to the title: No.
  4. phoenixck
    7 Jan 2012
    Fair enough bindi, I did say take with salt!
  5. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    I did read an article a while ago that mentioned skipping Ivy-E but plenty has been written since to suggest otherwise. I think Bindi's answer is plenty clear enough, too.
  6. Guest-16
    Guest-16 Guest
    I hope you understand I can't elaborate.
  7. Uxon
    Uxon Minimodder
    14 Dec 2010
    Hurrah for solder is what I say :D lets hope we see some decent clocking chips (hopefully without the power consumption of the SB-E hex cores).
  8. RedFlames
    23 Apr 2009
    Of course you *can*... you just not going to because you'll be beaten mercilessly by your employers... and/or fired...
    Reading between the lines... IB-E is just around the corner... [which in my head = sometime in the next 3-6 months]
  9. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    I am thinking the same, which is why I am holding off buying the waterblocks for my motherboard as I am waiting to see what the Rampage V Extreme is like, if/when it gets released but will have to wait and see.
  10. Guest-16
    Guest-16 Guest
    The 'cooks' are 'brewing' something 'tasty'.
    :worried:
    EDIT: (That's still a motherboard reference, not drugs)
  11. Harlequin
    Harlequin Modder
    4 Jun 2004
    IIRC IB-E is slated for September 2013 release
  12. Nexxo
    23 Oct 2001
    Is there a difference? :p
  13. Guest-16
    Guest-16 Guest
    Our motherboards are RoHS compliant. Try and smoke one if you want, but it's not like it used to be.
    notmeagain likes this.
  14. damien c
    31 Aug 2010
    Waterblocks already on the R5E please!!!!!!
    :D :thumb:
  15. Guest-16
    Guest-16 Guest
    We'll only ever do hybrid 'sinks, we can't only sell a waterblock. As such, all heatsinks require a specific level of thermal mass in order to be properly air cooled. With the limited space available for VRMs on the LGA2011, a hybrid 'sink is very difficult imo.
    That said, I'm not aware at all what RD are doing on any future projects. I only get shown once it's done. Maybe they solve it and go hybrid, I dunno. EK will undoubtedly make a kit though.
  16. damien c
    31 Aug 2010
    Hybrid is what I meant lol my bad.
    I hope they do manage it though with a barb thread rather than pre fitted barbs, so I can choose the tube size I want to use rather than being limited to one size.
  17. phoenixck
    7 Jan 2012
    I thought most recent hybrid boards had standard g1/4 holes to fit a barb of your choice?
  18. Guest-16
    Guest-16 Guest
    Yes they do. Every hybrid heatsink we do from now on will only feature G1/4s. It'll be fun to watch the rest of the field copy our design LOL ;)
  19. damien c
    31 Aug 2010
  20. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
