News Intel's Lynnfield will hit upwards of 2.3GHz DDR3
Discussion in 'Article Discussion' started by CardJoe, 22 Jul 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    2352? Niiiiiiiiiiiiiiiiiiiice! :)
    Waiting for benchmarks. Any hint on when other than "soooooooooooooooon"?
  3. dicobalt
    dicobalt What's a Dremel?
    21 Mar 2009
    Run that setup 24/7 and let us know if that ram fails.
  4. Zeus-Nolan
    Zeus-Nolan Minimodder
    2 Feb 2008
  5. dec
    dec [blank space]
    10 Jan 2009
    This lynnfield thing might be the holy grail of overclocking if that ram is fully stable and those 5ghz on air rumors are true
  6. OWNED66
    OWNED66 What's a Dremel?
    2 Sep 2007
    bit tech did it last time and they went up tp 4ghz :(
    i think it was bit tech
  7. wyx087
    wyx087 Multimodder
    15 Aug 2007
    no Uncore voltage options? am i right in saying Uncore are the quickpath bus controllers, in the same sense as northbridge are FSB controllers on LGA775?
    i hope they open up all options. otherwise LGA1156 will be a fail for tweakers and overclockers.
  8. Huxen5
    Huxen5 What's a Dremel?
    30 Jul 2008
    Could someone please state in brief what is going to happen with the intel processor sh*t (meant in a good way), I'm currently thinking that i'll buy a Core i7 920 and OC, am i right in sticking with that for the time being (futureproofing irrelevant) or is it worth waiting a month or two (considering i've been waiting for a loooong time anyway). I'm not sure whats going on with i5 and i7 or whatever...thx
  9. Huxen5
    30 Jul 2008
    If the difference between 1600MHz and 2000MHz is irrelevant (to gamers, not OC guys (and gals)) then does a jump to 2300 really matter?
  10. tejas
    tejas What's a Dremel?
    30 Sep 2008
    In AMD terms is Uncore the same as the Northbridge speed (CPU-NB)?
    I have AMD chips so just trying to make sense of the Intel Nehalem ones thanks.
  11. Guest-16
    Guest-16 Guest
    Yes, both the Intel and AMD "uncore" area are integrated northbridge and L3 cache.
Tags: Add Tags
