Modding Internalize speakers
Discussion in 'Modding' started by Noah, 5 Aug 2005.
  1. Noah
    Noah What's a Dremel?
    8 Feb 2004
    I have some speaker bars I'd like to use for my TVputer project.. but I don't want the extra plug, for the sound input or power.
    What would you recommend I do?
  2. Krog_Mod
    Krog_Mod Minimodder
    23 Sep 2003
    Explain your TVputer project if you could. If you're using a TV to put it all in you could replace the speakers inside the TV and maybe add in a small amp to run it through, adding some jacks to the side of the TV.. i mean if thats what your using for the case. Seriously though.. describe what ur gonna do, that'll help us help you out.
  3. Noah
    8 Feb 2004
    It's an LCD monitor attached to a plexi case with a computer inside, it will be a replacement for my 13" TV.
  4. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    i really like this idea, you dont ever see tv replacenments by a computer, but really it totally makes sense, i might do something like this w/ my old 15'' flat pannel
  5. TheEclypse
    TheEclypse What's a Dremel?
    11 Aug 2003
    Depends how big a TV you want.
