Networks IP Addresses from NTL.
Discussion in 'Hardware' started by Sim0n, 30 Jan 2002.
  1. Sim0n
    Sim0n rm -rf /
    14 Dec 2001
    Does anyone know how to change your IP address on NTL Cable.
    i know its a automatic thing, but i have Blackice on my PC and i have blocked the DHCP server so it cant connect to chage the IP.
    which has its advantages.
    But is there a easy command so i can lose the information, i have even tried unplugging the modem over night. No luck, any advice.
  2. neon85
    neon85 What's a Dremel?
    8 Jan 2002
    ip changing
    hello there my nottingham firend
    try takeing out all your stuff from your cable modem and leaving it over night i did it and it worked but it might of been just lucky as it was about due to change.
  3. PhsyCon
    PhsyCon What's a Dremel?
    7 Dec 2001
    Leave it off for 4 hours and the dhcp server should give you another IP. Either that or you can ring up NTL and get them to change it.
  4. neuro
    neuro What's a Dremel?
    9 Jan 2002
    i have Telewest cable, i wanted to change my IP as my connection was being attacked (over 500 alerts in my firewall per minutes!!!). customer services told me to unplug ALL leads from my modem for 24 hours. after doing that, new IP, no brute force attacks :D
