Modding Iris Basics *Updated 3/6*
Discussion in 'Modding' started by Astrum, 5 Mar 2003.
  1. 1398342003
    1398342003 Ubermodder
    2 Sep 2002
    Made sense to me. The rounded triangular bits (that poke out when the iris is open) are attached to each leaf, and fill the areas between the leaves.
    Not as pretty as a real iris though.
    I'd be done mine but I've been ill, and felt too lousy to even mod.
  2. Astrum
    Astrum Dare to dream.
    8 Mar 2002
    Stop using half circles. Optimum angle is about 135 degrees (or 3pi/4 radians). This is assuming the pivot point is half way between the outer circumference and the inner circumference of the leaf. It is also right on the end (you can round this end, aka, adding a half circle to the end).
    When you rotate this 45 degrees (or pi/4 rads) the leaf will reach to the middle, but not cross. It also won't be sticking out the sides, as it shouldn't be. Add more leaves, you get the cool spiral.
  3. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    theres nothng wrong wth constructng t wth half crcles and them choppng off all of the flyey oute bts, ths way, no calculus.
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    Ok, who stole all the i 's? :D
  5. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    OMG i think im Blind :rolleyes:
  6. :: Phat ::
    :: Phat :: Oooh shakalaka!
    7 Jun 2002
    methinks the I key finally copped it....
  7. Astrum
    8 Mar 2002
    Problem is you need a clean perpendicular cut at 135 degrees (3pi/4 rads). If you just chop off the extra, you can't be sure of where to make it perpendicular. And this is just basic geometry (with a tid bit o' trigonometry). If I wanted to make it perfect and describe it to you mathematically I would use a combination of Trig and Calc.
  8. Digitalblueshift
    12 Feb 2002
    yes the i key has dioed, but has been replaced buy a (really crappy) old keyboard. I WANT MY NEW ONE :waah: :waah: :waah:
  9. Digital Fodder
    Digital Fodder What's a Dremel?
    30 Aug 2001
    i didn't read the whoe thread but if someone could connect the iris to a fan motor so when the fan is off the iris closes and when it's spins up it opens. so it's all automatic.
    sorry if it has been mentioned.
  10. Digital Fodder
    30 Aug 2001
    or even better have a REALLY powerfull fan only turn on if the computer got to hot... opening the iris for 10 seconds then closing again.
  11. 1398342003
    2 Sep 2002
    It would be better to set the iris to the main computer power and have a seperate motor.
    It would be bad for temps.
  12. Astrum
    8 Mar 2002
    And it would be noisy.
  13. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    I'm not willing to let this die...I want to see completed examples!
    My idea is to build one out of plexi, based on this style posted by Splynncryth. I want to use one of these to cover the power button on the PC, combined with a proximitry (sp?) sensor so that when I move my finger towards it, it opens up to reveal the switch. This will go perfectly with the "Storm" case I am working up the plans for.
    My question is this: I must work with only one motor...surely there is a way to move all the doors with some sort of ring similiar to the iris method. Perhaps a slot for the driving pin to slide in?
  14. bHawk
    bHawk What's a Dremel?
    5 Jan 2002
    I second that! If someone actually completes this and posts a semi decent tutorial, id love to give it a shot when i have some more free time. Irises are just too cool.
  15. Astrum
    8 Mar 2002
    Maybe we should do something Shadow. I live in Denver =).
    I can't seem to find CAD, otherwise I would have posted some designed pieces I've done. Let me search through my stacks again.
  16. Shadowspawn
    1 Jul 2002
    Hey! Hows the snow? Probably all gone by now, or just about anyway...only thing left here is whats in shadows or piled up.
    I am racking my brain trying to come up with a way to move the doors via one mechanism. I will probably make the doors and inner ring this weekend...I do better when I can get my hands on it.
  17. Astrum
    8 Mar 2002
    Crappy snow... Car died because of it. I seriosuly need to replace some wires... :D . We got a couple feet here, and MASSIVE flooding. Water up to my waste...
    I have an idea of how to make that kind of... 'iris' work. The leaves would have to extend out of the ring even when closed a bit. The ring would have notches in the inner circle which would be able to push and pull the teeth on the leaves. The leaves would pivot about one point.
    You could get the motor to reverse directions (considering it is reversable) with a relay. I'll work on it a bit tonight. I see what you mean that it would be easier to make those leaves instead of intertwining, paper thin leaves, hehe.
  18. Shadowspawn
    1 Jul 2002
    The motor isnt a problem...I'm considering using a RC car servo...Ive got a few articles on how to control them. Just need to work out the mechanics of moving all the doors with only one motor.
    I'm not understanding your idea, about notches on the inner ring? I already imagine that the doors are going to be larger than the opening. That part will be invisible inside the case (the plexi walls will be covered with blue window tint, only allowing what I want to be seen and hiding the rest.) By making the doors extend past the opening, it will allow room for the pivots on each of the doors.
    I need to be independently wealthy so that I can work on this stuff day in and day out. Work and school sucks.
  19. Snood
    Snood What's a Dremel?
    27 Feb 2003
    i have access to a propper stage lighting iris thats perfect size for an 80mm fan. it costs about £70 to buy the real McCoy :miffed:
  20. Moreland
    Moreland banned
    16 Jan 2003
    Phat, well done on the excellent explanation, really intresting read and it gave me a few ideas.
