Storage Is it dead?
Discussion in 'Hardware' started by modfx, 3 Apr 2012.
  1. modfx
    modfx Loft Gremlin
    11 Feb 2010
    Hi Guys,
    I've started getting a windows error saying "Windows detected a hard disk problem" and basically tells me to back up my files and then change/repair/RMA the HDD.
    It started today and seems to pop up at random intervals ranging between 15 min to a couple of hours.
    How much do I panic?:worried::worried::worried:
  2. Pookeyhead
    30 Jan 2004
    Hve you backed up? If not.... Panic.... Then back up.
  3. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    This ^^ unless its not important information then take a sledge hammer to it and buy a new one
  4. modfx
    modfx Loft Gremlin
    11 Feb 2010
    Yep, anything I care about is backed up, reckon now is a good excuse to hold off the monitor upgrade (again) and get a SSD?
  5. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    What size drive is it ? An ssd will never be a bad upgrade from a mechanical HDD :p
  6. modfx
    modfx Loft Gremlin
    11 Feb 2010
    1 TB Samsung Spinpoint F3, just noticed I've spelt spinpoint wrong in my sig.
    Have been mulling over getting one for a while but I can never justify it over a MB, GPU, CPU etc upgrade.
  7. faugusztin
    11 Aug 2008
    1) back up data
    2) depending on hard drive manufacturer get the official tool for the specific brand :
    Western Digital Data Lifeguard Diagnostic
    Seagate Seatools
    Samsung - no idea, HUTIL probably, but i guess someone else will give you the exact name of the tool
    Test the drive, if it says it is bad then RMA it.
  8. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    You would have to lose a lot of information to be able to switch to an SSD then, or spend big bucks ! As im typing this i think my F3 is dying :(, movies keep freezing and then drive is unresponsive. Fuuu such a bad time to buy a mechanical hdd now too.
  9. faugusztin
    11 Aug 2008
    Still not as bad as few months ago. Preflood price of WD20EARX - 71 euro. Post flood price - 150-200 euro. Current price - 105-115 euro. Not the preflood price, but already lower than 1,5-2 years ago (at that time, it was 135 euro if i remember correctly).
  10. modfx
    modfx Loft Gremlin
    11 Feb 2010
    Doing that now, I think it has a 36 month warranty with scan so should be able to RMA but I don't want to be without a PC for even a couple of days, seeing that Scan no longer have it listed, I'm guessing it may be a bit longer than that.
  11. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Scan do still sell the F3, i have just looked :)
  12. modfx
    modfx Loft Gremlin
    11 Feb 2010
    I can has linky please? can't seem to find it :<
  13. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    DOH didn't look properly, its only the 500GB well thats a fooker. Says direct RMA on samsung drives anyway so save the time and RMA it to samsung direct, i think thats where mine is going to end up :(
  14. mattyh1995
    mattyh1995 Minimodder
    1 Oct 2011
    A little offtopic, an appropriate second test to see if anything is dead = poke it with a stick.
  15. modfx
    modfx Loft Gremlin
    11 Feb 2010
    Yarp. Now,the question is: What shall be my new HDD?
  16. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    We talking SSD...if so, what size ? 128gb would be nice...i run an M4.
  17. modfx
    modfx Loft Gremlin
    11 Feb 2010
    I was looking at that. Will my motherboard support it?
  18. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    Okay, if your mechanical HDD is dead, there is one solution that might work when you have nothing to use. Grab the drive, find a hard surface, and just give it a good solid smack on the surface. Not hard enough to damage the exterior, but enough to dislodge any stuck parts. Obviously do it when the drive is powered off. It has saved a couple drives for me, and done nothing on a couple more. It's worth a try since if it doesn't work you haven't exactly lost anything you weren't going to use anyways.
  19. faugusztin
    11 Aug 2008
    Mac_Trekkie, are you serious ? For starters, he will lose warranty if he does that. Second, his drive works, but corrupts data. That means he has platter surface problems, and no "stuck parts".
  20. modfx
    modfx Loft Gremlin
    11 Feb 2010
    Not whacking it on anything lol.
    I'll decide and order whatever SSD I'm getting tonight and rma the f3 when it turns up. Other than the pop up,no issues so far apart from maybe a little slowdown in game loading so hopefully it will last until then.
    I think I might get a 128Gb crucial m4, seems like a good choice going by several members sig. The price seems reasonable too. I'm open to suggestion though.
    Either way, thanks a lot for the advice, much appreciated :)
