Is Xbox easily fixable?
Discussion in 'Gaming' started by daguuy, 25 Jul 2006.
  1. daguuy
    daguuy I hate lolcats
    18 Jul 2005
    i'm gonna have to get an XBOX eventually but i don't have an extra $150 laying around for one so if i get one i'll have to do what i did to get my PS2 and GC: get one free with a disk reading problem and fix it. i know you can easily and pretty reliably do that with those 2 but what about XBOX? is there a cheap/free and reliable way to fix XBOX DVD drives?
  2. DougEdey
    5 Jul 2005
    XBOX drives can be picked up for around £40-£50. Don't know the going rate in the US, but a second hand fully working xbox is between £50 and £70 (depending on boxed).
    So its just worth getting a 2nd hand one.
  3. daguuy
    18 Jul 2005
    is there any way to make it work with any other normal computer DVD drive? if i remember correctly, they use the same IDE connector but they might have some kind of security/compatability issue with that.
  4. Guest-16
    Guest-16 Guest
    You need to buy a specific model and use an Xbox BIOS. Ive tried a direct replacement and it doesnt work, for starters the power plug is different and it encorporates the eject plug at the back
  5. mushky
    mushky gimme snails
    24 Mar 2003
    You can tweak the pots in the dvd drives quite easily which may or may not sort out a DRE. Check out the tutorials here
  6. daguuy
    18 Jul 2005
    Thanks! that's just what i needed. i guess replacing the drive would be too much work, pots are easy to deal with
