I know ITX is 170mm x 170mm but what is the height of them, can't find anything about that anywhere! Say in an EPIA M10000 or EPIA MII? Cheers
Epia MII : http://www.viavpsd.com/product/3/4/EPIA-MII Operation Guide_V1.0_20031205.pdf (0,96 Mo) Epia M : http://www.viavpsd.com/product/3/4/EPIA M Operating Guidelines Version 1.20.pdf (677 ko) Both are 44,45 mm...
the tallest bit is the sound connectors, the actual fan and heatsink are very small (fan alone is 10mm), providing you leave enough space for the sound conectors you should have plenty of airflow
I too need to worry about my case size and motherboard dimensions, does anyone know the height of the northbridge heatsink on the video chipset. I might need to remove it if its in the way of my Slimline CDR/DVD combo drive. And if i do need to remove it does anyone know where i can find a low profile heatsink for this chipset? (in the worst case couldn't i just take off the heatsink and have it trimmed down to size?)
