Itx tower pc case
Discussion in 'Hardware' started by weed2all, 26 Apr 2019.
  1. weed2all
    weed2all modder
    24 Oct 2011
    Hi everybody, so I want to build a new itx system for my cad design and some stuff I had some stuff i needed to buy. Now I only need a PC case to accommodate the hardware that I have:
    Motherboard : Z390 phantom gaming-itx/ac (bought new few hours ago)
    CPU : Intel i9 9900k(bought new few hours ago)
    GPU : Asus GeForce GTX 1060 Expedition OC 6GB GDDR5 (already had it)
    RAM : G.SKILL Aegis 16GB (2x8GB) DDR4 3000MHz CL16 Black(already had them)
    HDD : SSD M.2 2280 Kingston 240GB(already had it) this is for windows files
    HDD2 : 2tb for storage(need to buy one)
    CPU COOLER : Cooler Master MasterLiquid ML240L( already have it)
    PSU : CORSAIR SF600 80 Plus Gold(bought new)
    PC case needed
  2. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Phanteks Evolv ITX is a great case that is quite large for the form factor, but makes for a very easy and clean build with lots of cooling potential for high-end parts (check the link in my sig).
    weed2all likes this.
  3. weed2all
    weed2all modder
    24 Oct 2011
    I saw this case and it is affordable, but im not sure that i have space to install 240 radiator...can tell me for sure that this case can accommodate the radiator?
  4. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    I have the Evolve ITX with a Cooler Master MasterLiquid ML240L in the top.
    I can take a picture and post when I get home if you like?
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    You can do full custom watercooling in it, so you'll be fine! The Phanteks Shift X will do it too.
  6. jsbombjack
    jsbombjack Minimodder
    14 Mar 2015
    I just bought the Fractal Design Nano S. Decent price on Scan at £57
    Not managed to build everything into yet as the MB does not arrive until next week (and I am away all next week anyway). That said, there is a lot of space in it for all sorts of hardware. I would just suggest an SFX power supply to give that little bit extra room around the GPU. Having measured, it will take a gigabyte windforce 2080ti, but not the Palit Dual of the same if you have a radiator and fans in the front rather than the top
  7. weed2all
    weed2all modder
    24 Oct 2011
    It will be nice to see...
  8. weed2all
    weed2all modder
    24 Oct 2011
    Yes...for the psu I just bought an corsair sf600 gold plus psu...that is small form factor psu!
  9. jsbombjack
    14 Mar 2015
    I got the evga 650w sfx power supply. Fits a treat and would mean the fractal could take a 2.5 slot wide gfx card without breathing issues on the first fan
  10. MightyBenihana
    MightyBenihana Colour my life with the chaos of trouble
    8 Sep 2011
    Do you think a 2.75 slot card would be an issue with the Corsair SFX PSUs?
  11. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    A couple of photos (Google is your friend) show there will be room, as long as the ATX to SFX adapter allows mounting the PSU at the bottom in the Nano S (e.g. the Silverstone adapter).
    The top picture is with a Gigabyte Aorus 1080Ti which is a 3 slot card.
  12. jsbombjack
    14 Mar 2015
    With the evga one, using the bracket that came with it (which must be similar if not the same as a Silverstone one) you effectively get another 2 slots worth of space, so a 3 slot card should fit in the case with an sfx power without issue.
    That said, I bought the gigabyte windforce 2080ti, which is a 2 slot card but fits length-wise even with a 240 rad and fans in the front of the case
  13. weed2all
    weed2all modder
    24 Oct 2011
    This is a sweet looking rig...I can wait to get mine installed!
  14. MightyBenihana
    8 Sep 2011
    @Fingers66 I had been looking for 2080tis in that case on Google. Hadn't figgered to look for 3 slot 1080tis as a reference. I am slow.
  15. meandmymouth
    15 Sep 2009
  16. jsbombjack
    14 Mar 2015
    Fyi this is the clearance of a 2 slot windforce 2080ti with a 240mm corsair 100x, evga sfx all in a fractal nano s
    MightyBenihana likes this.
  17. Fingers66
    30 Apr 2010
    Fits like a glove!
    :grin::grin::grin:
  18. jsbombjack
    14 Mar 2015
    Almost like I measured it...
  19. weed2all
    weed2all modder
    24 Oct 2011
    Ok..decided to go with phantek evolv itx route...as it is the most affordable and kinda nice little case...I will update as soon as I receive the case and begin to install all the components...
  20. weed2all
    weed2all modder
    24 Oct 2011
    Here it is...almost done...made a 3d printed custom plate for wiring management, because I like to have the wires straight...just needed to cut a small rectangle above the big oval hole and then i fixed that red plate with m3 screws....
    It came along very nice...with plenty of room for a custom watercooler...though I'm thinking to modify further more the case by complete removing the plate where the radiator mounts and cut 2 holes on the top of the case and mount the radiator permanently on it...and also upgrade the 200mm front fan with a noctua one...or 2 140mm fan for blowing fresh air into the case as well I'm planning to put an an acrylic window to the side panel...
    jsbombjack likes this.
