Hi. I'm trying to make a tabs menu that supports a second horizontal level when the mouse rolls over one of the tabs, using tutorials and other examples. I've got the majority of it working, just has a few bugs and I want it to automatically select a default tab. Main Tabs: Code: <div id="mainmenu" class="float-break"> <ul> <li id="main-1"><a onmouseover="switchMenues(1);" href="link"><span>tab1</span></a></li> <li id="main-2"><a onmouseover="switchMenues(2);"><span>tab2</span></a></li> <li id="main-3"><a onmouseover="switchMenues(3);"><span>tab3</span></a></li> <li id="main-4"><a onmouseover="switchMenues(4);"><span>tab4</span></a></li> <li id="main-5"><a onmouseover="switchMenues(5);"><span>tab5</span></a></li> <li id="main-6"><a onmouseover="switchMenues(6);"><span>tab6</span></a></li> <li id="main-7"><a onmouseover="switchMenues(7);" href="link"><span>tab7</span></a></li> </ul> </div> Sub Tabs: Code: <div id="submenu" class="float-break"> <script type="text/javascript"> <!-- var subOne = '<ul id="sub-1" class="sub hide float-break"> <li><a>main1:Sub1</a></li> <li><a>main1:Sub2</a></li> </ul>'; var subTwo = '<ul id="sub-2" class="sub hide float-break"> <li><a>main2:Sub1</a></li> </ul>'; var subThree = '<ul id="sub-3" class="sub hide float-break"> <li><a>main3:Sub1</a></li> </ul>'; var subFour = '<ul id="sub-4" class="sub hide float-break"> <li><a>main4:Sub1</a></li> </ul>'; var subFive = '<ul id="sub-5" class="sub hide float-break"> <li><a>main5:Sub1</a></li> </ul>'; var subSix = '<ul id="sub-6" class="sub hide float-break"> <li><a>main6:Sub1</a></li> </ul>'; var subSeven = '<ul id="sub-7" class="sub hide float-break"> <li><a>main7:Sub1</a></li> </ul>'; var mainTabs = ['main-1', 'main-2', 'main-3', 'main-4', 'main-5', 'main-6', 'main-7']; var subMenus = ['sub-1', 'sub-2', 'sub-3', 'sub-4', 'sub-5', 'sub-6', 'sub-7']; document.write( subOne, subTwo, subThree, subFour, subFive, subSix, subSeven ); --> </script> </div> javascript: Code: function switchMenues(menuNumber) { for ( i = 1; i < mainTabs.length; i++ ) { document.getElementById(mainTabs[i]).className = ''; } if ( menuNumber != 0 ) document.getElementById(mainTabs[menuNumber]).className = tabHighlightClass; for ( i = 0; i < subMenus.length; i++ ) { document.getElementById(subMenus[i]).style.display = 'none'; } document.getElementById(subMenus[menuNumber]).style.display = 'block'; } However it doesnt work unless I add an additional '' to the "var mainTabs" and an additional sub category to "var subMenus " for example: Code: var mainTabs = ['', 'main-1', 'main-2', 'main-3', 'main-4', 'main-5', 'main-6', 'main-7']; var subMenus = ['sub-1', 'sub-1', 'sub-2', 'sub-3', 'sub-4', 'sub-5', 'sub-6', 'sub-7']; then works but is a little messy and I dont understand why. Finally if you could tell me how to select the Main-1 tab by default that would be great. Thanks v.much!! Kingdavies
