Modding Jigsaw question before I get started
Discussion in 'Modding' started by Jbroad572, 15 Oct 2004.
  1. Jbroad572
    Jbroad572 What's a Dremel?
    22 Sep 2004
    Well, got the side panel taped up and outlined. I plan on using a dremel to start a hole then use my jigsaw from there. Only thing is, I don't have any kind of workbench or anything similar. Just a one bdrm apt with a wooden bench. Can I just clamp my panel to the wodden bench or even a counter top and just cut the side that's hanging over? IS that a bad idea?
  2. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    I tried something like that. It worked, but the whole thing had to be held by somone else because it shook so much.
  3. Jbroad572
    22 Sep 2004
    Ahhh, so the clamps weren't stron enough? Maybe I can find something that's real heavy I can also place on top of it.
  4. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    The clamps were fine, but the side that wasn't clamped wiggled too much.
  5. rankie
    rankie What's a Dremel?
    12 May 2004
    i've cut half a window with the case in my lap, but then it started to move up and down with the blade insted of having the blade cut it
