Modding Joining two cases, what method?
Discussion in 'Modding' started by Mord, 21 Apr 2004.
  1. Mord
    Mord What's a Dremel?
    7 Mar 2004
    I have to cases ready for project behemoth where by i plan to fix these cases together. My only (major) problem is I don’t know or have the tool for welding.
    The only tools I do have are: a dremel, jigsaw, hand drill, soldering iron and basic electronics tools such as screwdriver / pliers etc.
    Bearing in mind I want to join these cases side by side permanently, what sort of options do you think I have?
  2. Trekari
    Trekari What's a Dremel?
    10 Nov 2002
  3. noCode
    noCode What's a Dremel?
    16 Oct 2003
    Drill holes and bolt them together? Or do like i did, drill holes and bolt them together with hinges.
  4. Mord
    7 Mar 2004
    Spose i could bolt them, but the metal rim that the side panels rest on are a bit thin, small and flimsy.
    Ill have a second look.
  5. Nova Kain
    Nova Kain What's a Dremel?
    23 Apr 2004
    hehe, looks like an internal view of Pac-man
  6. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    :hehe: :hehe: :hehe:
    You know what, it really does!
    Cheers,
    Mike
  7. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    cut out a metal plate the asize of the two bases combined, and bolt it to the bottom of both of the cases.
  8. Tt Ownage
    Tt Ownage What's a Dremel?
    1 Feb 2004
  9. kh15
    kh15 What's a Dremel?
    10 Mar 2004
    dont use gorrilla glue that stuff is for wood only and will simply peel off of metal not to mention its an expanding glue so you would have to clamp the hell out of you two cases to get them to stay put while the glue dried. find a local metal shop or a school with a metal shop any thing with a spot welder and they will be happy to put a few spot welds in it for you and it would take about 5 minutes and it would last you a life time thats what i would do
