Build Advice Just need CPU/Mobo & Ram...or do I?
Discussion in 'Hardware' started by Randomeclipse, 31 May 2011.
  1. BitHeroes
    BitHeroes What's a Dremel?
    1 Jun 2011
    Post a picture!
  2. T2I3M
    T2I3M Minimodder
    13 Mar 2010
    How old is the case? Maybe check the website? Or post some pics, im sure somebody here will know what model it is lol
  3. murraynt
    murraynt Modder
    6 Jun 2009
    Also when you are posting the pic of the case rip the side off so we can see the hsf.
    +1 to the XMS3 ram aswell.
  4. Randomeclipse
    Randomeclipse Minimodder
    11 Jan 2011
    Ok, firstly I can confirm the GPU is a 5770 :)
    Now pics...
    Side shot
    Inside HSF shot
  5. murraynt
    murraynt Modder
    6 Jun 2009
    I think you can add a coolermater 212 hyper + to the list :)
  6. Randomeclipse
    11 Jan 2011
  7. Randomeclipse
    11 Jan 2011
    Any ideas on the model of the case?
  8. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Looks like a variant of the PC-60, I can't remember the exact model number though. Does it matter what model it is?
    I use an older version of that case with my setup. If you're tight on funds, there's no point changing the case.
  9. Randomeclipse
    11 Jan 2011
    Yeah I hadn't planned to change the case, but while I think about it is that type of case an ATX?
  10. Tangster
    23 May 2009
    A good dust and cable tidy would probably be a good thing as well.
  11. Randomeclipse
    11 Jan 2011
    I thought someone would say that :). Guilt as charged though..
  12. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    To me before you do anything else the PSU should be higher quality & power. GPU is weak but I'd still do Mobo/CPU/RAM first, also agree on the XMS3 over Dominator. And a clean-up if you're keeping the case :p
  13. oasked
    24 Aug 2005
    Yes, its an ATX case. :)
  14. Randomeclipse
    11 Jan 2011
    I kind of think if it's a perfectly good case, both condition and look wise then why would I need to replace it.
    Going to check but for around the £400 mark I should be able to get the majority of bits, then possibly save for a couple of months and find another GPU.
  15. Randomeclipse
    11 Jan 2011
    Ok, managed to get it down to £370, which will include:
    Intel Core i5-2500 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail
    530W Be Quiet! Pure Power BQT L7 ATX2.3 Power Supply
    ASUS P8P67-M PRO Intel P67 (REV B3) Socket 1155 DDR3 PCI-Express Motherboard
    4GB Corsair XMS3 (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit - CMX4GX3M2A1600C9
    Coolermaster Hyper 212 Plus CPU Cooler
    I'm going to (for the short-term) keep the Case (Lian-Li PC60), keep the GPU (5770) and keep the 350gb WB HDD.
    Anything I could swap out you think in the mean-time as I think my budget it pretty much maxed (for the time being) and it will hopefully improve my gaming experience.
    May even try to overclock it if I'm feeling ambitious :)
  16. murraynt
    murraynt Modder
    6 Jun 2009
    swap the baord out for the MSI P67A-GD53
  17. Randomeclipse
    11 Jan 2011
    Is that just a bang for buck decision, murraynt or is the MSI board a better choice hands down?
  18. lm_wfc
    lm_wfc Minimodder
    18 Feb 2011
    Don't know much about wow, but I'd imagine a new graphics card would help a lot more than the processor.
  19. Randomeclipse
    11 Jan 2011
    That will hopefully be my next port of call in the next month or two, but wanted to pick up the other bits now and look for a bargain decent GPU in the coming weeks.
  20. Randomeclipse
    11 Jan 2011
    P.S. will the MSI board allow equal overclocking potential to the ASUS board?
