Case Mod - In Progress K.3nny's C-BonizeD DangerDen acrylictubes!
Discussion in 'Project Logs' started by k.3nny, 26 Sep 2012.
  1. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Heey lads,
    I had a break for like 8? months :p so i started this 1 week ago :)
    Let go!
    Put the case onto the Carbon vinyl
    Cut everything out
    Stick it!
    Thnks to L3P i had some black assortiment of inbusses :rock::thumb:
    Finished!
    Tried something original with the Window panel :)
    Better pics in Daylight.
    Bought some random hardware ;)
    New:
    OCZ OCZSSD2-2VTXE120G, voor die 60 euro ;)
    Used
    Mobo en Cpu :)
    Asus Rog maximus 3
    Intel 875K
    Carbonize the cpu block till i can afford a identical plexi one :)
    mobo with memory build:)
    Testfit in the case, getting cramped already :p
    I have some little room left
    With sidepanel
    positioned the Dual pump and drilled the holes for it.
    Bought at my local plumber store 2 metre of acrylic tubing.
    First try:)
    My working bench ;)
    Heat it up, hold it inplace, take a sprint to kitchen and cool it down, mission succesfull!
    Bp C47 where in the mail, gladly :D!:
    Same as the SSD!
    Prepared the tubing for the fittings, Just like Kier does, grind a 8mm edge.
    Then i used speedhack! lol, i forgt to make shots of the buildup progress :p
    I dont have budget for the sleeving, maybe next month :)
    Because there is no room between panel and mobotray, i need to route everything between the mobo and the mobopanel, but it worked :)
    thats all folks!
    :sigh::rock::rock:
    YEHBABY likes this.
  2. whyte
    whyte What's a Dremel?
    27 Mar 2012
    Really love the case. The window you made is amazing. And last but not least, the acrylic tubes are sooo coool.
  3. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    k.3nny, bout time your back. This is freaking killer man. How long did it take to get the case all done.
  4. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Wrapping about 30 mins :)
    Plumbing, around 4 hours :)
  5. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Nice job on the CF and tubing!
  6. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Ty sir!
  7. k4p84
    k4p84 What's a Dremel?
    20 Aug 2008
    Hey,
    Very nice build you have there.
    Regards
    Ed
  8. maestro0428
    maestro0428 Master Modder
    24 Jun 2010
    Now that is how tubing is done! That looks so much better than all those damn fittings. Never been a fans of those. Nice work.
  9. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Thnks ed :D!
    Haha, yeah i was tired of the tubing also, always so "hanging around"
    So, i fixed it :jawdrop: :thumb:
  10. jrs77
    jrs77 Modder
    17 Feb 2006
    These TFC Triebwerk fans are really badass :)
  11. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Some what clearer pics taken with a handycam :)
    not allot of tekst, just better pics
    Did some random sleeving, put 24/gpu extenders, black SATA cable and much better cablemanagement :)
    Also did a boot :)
  12. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Soo, its quite done now, The system is up and running smoothly after some flaws,
    First, because the solid tubing didnt expand to pick up the pressure what was left behind when u turn the system off i had some minor leaks, after a little chat Peter(l3p) came with an idea, that was to make a kind of balance line of 1/2tubing, so i made it like he suggested, and damn it worked, was a miracle! its running real smoothly now, Gladly ;)
    Piics :)
  13. Oso Polar
    Oso Polar What's a Dremel?
    20 Sep 2012
    looks awesome mate. Great job!
  14. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Thnks :D!
  15. l3p
    l3p www.^.nl
    1 Nov 2010
    Love the piping Kenneth! :)
  16. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Sweet build man!
  17. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Nice work :)
  18. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Thnks L3p :rock:
    thnks :D!
    Thnks man :D! I like the standup bench your doin! :brrr:
  19. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Stil leakfree!
    after 24 days
    stresstest and gaming etc no problem :D!
  20. bulldogjeff
    2 Mar 2010
    I missed this whole project some how.. That is a wicked build Kenny, it all just works really well together. I love the idea for using solid clear tubing as well.
    Another top build, well done dude. Looks brilliant.:thumb:
