K6-2 400
Discussion in 'General' started by Gandi69, 17 Oct 2001.
  1. Gandi69
    Gandi69 Like to get busy wit fizzy..
    17 Jul 2001
    wot shud I do with my old K6-2 400@450 in a Gigabyte GA5AX. Shud I sell it or wot?
  2. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Send it to valhalla :)
  3. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    i have a k6-3 400 sitting in a gigabyte ga-5ax .. waiting to set it up as a server ;)
  4. Cheese
    Cheese Doc
    6 Oct 2001
    Keyring time...
    :D
    r.
  5. acron^
    acron^ ePeen++;
    15 Oct 2001
    Why dont you re-build it like i told you??
    Then sell it in the paper to some old dear for £200 :)
    Ignorance is bliss, eh? ;)
  6. Gandi69
    17 Jul 2001
    Shud i jus sell it as is then? i cant afford to do it up lol
  7. Gandi69
    17 Jul 2001
    BTW how much can i get 4 it?
  8. RTT
    RTT #parp
    12 Mar 2001
    andy from what i can see, if you put a voodoo 3 in it, put a 8gb hdd in it, replace the case and put 128mb ram in, you;ll be able to get £300 for it easy.
    someone was selling a p266, 64mb ram, 4gb hdd etc for like £200.
    advertise for 350, let them haggle down to 300 and they'll think they're getting a great deal :D
  9. Gandi69
    17 Jul 2001
    LoL man. If I hav sum spare cash I will. In the paper ppl sell like 120s with 16mb ram for like £400!!!
  10. Oliver
    Oliver What's a Dremel?
    1 Sep 2001
    Well the board and chip together might fetch about £45 I suppose...
    Freddy:
    "Why dont you re-build it like i told you??
    Ignorance is bliss, eh?"
    Personally I would think that the old dear in question would be getting a pretty good deal as long as the other bits were up to scratch!
    K6-2 400, 128mb ram, 4Gb hard drive, cd drive, sound card & speakers, modem, keyboard + mouse, monitor.
    That is a pretty good system - apart from playing games it will do anything you ask it to. It will run WinME or 2K very nicely, will browse the net as fast as a modern system, and will run any office apps that average people would want....
    For our LAN parties, we have a recomended minimum spec of PII 300 with a Voodoo II and 128Mb ram, and an old K6-2 with a cheep Voodoo 3 will do a very good job of playing CS, UT & Q3.
    The K6-2 may be old and looked down upon, but it still makes a very capable system!
  11. [GiB] Spawny
    [GiB] Spawny Xqpack Lovin
    2 May 2001
    My Choice.
    Set it up as a server.
    Stick some extra ram in it and a FAT 30Gig hard drive
    Cross over cable connection to your other box
    Bobs your Uncle.
    You can use it for:
    MP3's
    Patches
    Downloads
    Backups
    Keeps you normal rig clean and less clogged with pap. The added advantage is that you will have a back up box to work on if your main one falls over.
    I've only just got rid of my P90 with a 20gig hard drive.
  12. Phil
    Phil What's a Dremel?
    19 Jul 2001
    I'll give you £30 +p&p for the mobo
    I have a K6-III 450 but the mobo it was in died
  13. linear
    linear Minimodder
    5 Oct 2001
    For informational purposes only:
    I remember a scam from back in the P*ntium days that went like this... The shady vendor sold systems as P*ntium 166 for a a decent price. But when you took delivery, there was a P*ntium 100 in the socket, and the "My Computer" icon on the desktop was renamed to "P*ntium 100." The vendor explained how there was a shortage on the 166 chips, and offered a free, in-house upgrade as soon as the 166s arrived. Most sheep bought the things, and then the tech would follow on in a week, go to the system and rename the icon from P*ntium 100 to P*ntium 166, never opening the case. Worked like a charm, I hear.
  14. Gandi69
    17 Jul 2001
    wud u pay anymor that £30 for it? ps: this mobo is extremely stable.
  15. Phil
    19 Jul 2001
    if you can find an old DIMM to go in it (it does take dimms not simms don't it ?) I'll give you a bit more....
    mobo + 32meg £35
    mobo + 64meg £40
  16. alipuk
    alipuk What's a Dremel?
    18 Aug 2001
    Why not stick linux on it and try and figure that os out?
  17. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    The GA-5AX takes DIMMS .. pc66, pc100 and pc133. I used em all in it. I had 256 in it at one time, one pc66 and one pc133 and it worked just great !!!
    Had it with a k6-2/550 at the time, and then mysteriously just "got" a second board which I used in family pc. Which I recently upgraded to a BE6-2 Rev 2 and celery 466 ... so I have a spare GA-5AX waiting for a new use :)
  18. Phil
    19 Jul 2001
    would you like to sell it ? :D
  19. RTT
    RTT #parp
    12 Mar 2001
    i dunno wether i wanna sell my ga5-ax
    i cud either use it as a linux box or file server or sell it :)
    ga5-ax + 128mb pc100 for 50?
  20. Gandi69
    17 Jul 2001
    Yeh I'll sell it m8. Jus gotta get this rig running rite 1st :)
