Windows Kazaa 2 Participation Level
Discussion in 'Software' started by sinizterguy, 13 Dec 2002.
  1. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Does the participation level make any difference to either the speed of downloads or the preference ?
    Don't see much difference whether my participation level is 1000 or 1 ... so was wondering what the purpose of it was
  2. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    If there's something that a LOT of people want to download and few slots available, it will chuck off someone with a lower participation level in favour of someone with higher. If you're downloading stuff that there's more supply than demand, you'll see no difference.
  3. sinizterguy
    25 Jul 2002
  4. quack
    quack Minimodder
    6 Mar 2002
    There were ways to increase your level by cheating but Kazaa 2.0.2 stops all the known methods.
    I hope you use KazaaLite btw :)
  5. sinizterguy
    25 Jul 2002
    I use KazaaLite 2.x with Diet Kaza
    I think the program KLite cheater or something does increase the participation levels.
    Not really sure about it
  6. War-Rasta
    War-Rasta What's a Dremel?
    22 May 2002
    u bet it does!!
    it increases mine in the blink of an eye. just befor u can say Warez!!
  7. VadimtheConqueror
    VadimtheConqueror I love the little tacos...
    10 Jul 2002
    i was using kazaalite, but it wasnt renaming the files once they finished, was leaving them as .dat files, which was fine aslong as i didnt close the program, so i could get the exact file size, find the file with that size in my folder, and manually rename it, but that was a pain in the ass, so i just got regular kaz again
  8. sinizterguy
    25 Jul 2002
    Been using kazaalite ever since it came out.... absolutely no problems for me...
    mebbe you should try uninstalling, removing all registry entries and installing again :)
  9. VadimtheConqueror
    10 Jul 2002
    it's really not worth the effort, imho
  10. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    I set my uploads to 4 slots and when I don't need my upstream I allow people to take my stuff. My participation level is at Supreme Being (1000) 90% of the time...
  11. quack
    quack Minimodder
    6 Mar 2002
    I take it you don't care about spyware then. Just be warned that Kazaa installs the Brilliant Digital viewer and ALTnet which will allow Brilliant to use your CPU power to serve adverts to you and other people without your knowledge. Enjoy :)
  12. VadimtheConqueror
    10 Jul 2002
  13. g_gimbert
    g_gimbert Minimodder
    9 Jun 2002
    my participation seems to drop all the time.....currently around 40....even tho im sharin my files:S
    anyone know why this is happenin??
  14. ouija
    10 Nov 2002
    You download files, your level drops.
  15. Gretzky
    Gretzky What's a Dremel?
    6 Nov 2002
    I dunno but I dont like Kazaa lite. Direct Connect seems much better. But thats just my opinion which i know means nothing hehehe :D
  16. sinizterguy
    25 Jul 2002
    I like DC too ... but not that much ... the problem is finding the files you want and a user who has free slots and is fast enough = too much trouble if you just want to download a coupla songs.
  17. DeX
    DeX Mube Codder
    22 Jul 2002
    Yeah and you can't download off of several users at once with DC.
    Anyway if your files aren't renaming themselves it's probably because you don't have enough disk space. I think that happened to me a few times when I was running low on space. I think you may need more than twice the file size worth of space.
  18. Altron
    Altron Minimodder
    12 Dec 2002
    I have KazaaLite
    I don't let anyone else have my files. I only open to DL then I close it (get it off taskbar too)
  19. sinizterguy
    25 Jul 2002
    That's exactly what I do, exept I use Diet Kaza too... to help me get more search results and to download from more sources at the same time and block spywayre/adware and stuff like that
  20. Phrozenpenguin
    Phrozenpenguin What's a Dremel?
    11 Dec 2001
    Hey d00d, share, keep the network alive :) Uploading doesnt kill your download speed....
    I use the KL cheater to get 1000 level, but i share as well.
